Classifieds » Miscellaneous » SOLD *7m Flywheel, Pressure plate, Clutch* SOLD
acmtt
SOLD *7m Flywheel, Pressure plate, Clutch* SOLD Sat, 31 July 2004 12:45 Go to next message
I bought these as part of a conversion kit to get the pedals.
I cannot confirm that they are 7m, maybe someone here knows.
They have surface rust.
Clutch has good meat still.
Flywheel will be fine with machining.
Pressure plate isn't pretty .
I am in Melbourne S.E suburbs.
Andrew
http://forums.toymods.org.au/index.php?t=getfile&id=5887
http://forums.toymods.org.au/index.php?t=getfile&id=5888
http://forums.toymods.org.au/index.php?t=getfile&id=5889
Attachment: Flywheel.jpg
(Size: 60.01KB, Downloaded 75 time(s))
Attachment: Clutch.jpg
(Size: 82.05KB, Downloaded 75 time(s))
Attachment: Pressure-plate.jpg
(Size: 91.21KB, Downloaded 66 time(s))
[Updated on: Sun, 01 August 2004 11:47]
cambelt
melb
Re: 7m Flywheel, Pressure plate, Clutch Sat, 31 July 2004 14:18 Go to previous messageGo to next message
interested,deffinatly looks like 7m non turbo , pm sent
[Updated on: Sat, 31 July 2004 14:27]
Re: 7m Flywheel, Pressure plate, Clutch Sun, 01 August 2004 00:42 Go to previous messageGo to next message
7M, non turbo.
Pressure and clutch plate also good for 2JZGE.
Fattony
Re: 7m Flywheel, Pressure plate, Clutch Sun, 01 August 2004 02:29 Go to previous messageGo to next message
Yep that defnitly does look like a 7mge setup, measure the depth of your p plate, that should be about 50mm or therabouts. You could also mate this setup up to a 1g, however you would need to modify your thrust bearing carrier to be 10mm shorter beacuase the p plate is 10mm thicker. You will find that you can get a heavier p plate for this flywheel than what you can for a 1g flywheel.
acmtt
Re: 7m Flywheel, Pressure plate, Clutch Sun, 01 August 2004 03:50 Go to previous messageGo to next message
Correct. Pressure plate is 49mm thick.
Andrew
joecoolmk2
Re: 7m Flywheel, Pressure plate, Clutch Sun, 01 August 2004 09:01 Go to previous messageGo to next message
is this setup much better than a 4m's setup? or should i just get an aftermarket kit? aiming for about 200hp
acmtt
Re: 7m Flywheel, Pressure plate, Clutch Sun, 01 August 2004 11:46 Go to previous message
OK Guys its gone. SOLD.
Previous Topic:got turbo timers and air filter for sale cheap!
Next Topic:15" wheels for sale NOW $260
Current Time: Wed Oct 21 03:49:10 UTC 2026
Total time taken to generate the page: 0.099769115447998 seconds
