Toymods » Tech & Conversions » Shredded Timing Belt, 7MGE
xl912
Shredded Timing Belt, 7MGE Sun, 01 August 2004 09:36 Go to next message
Hi all,
Anyone have any ideas why a 7MGE (3.0 litre 24v Cressida) keeps shredding timing belts?
It's eaten 2 recently; inless than 2,000 km!
Robert
SIMDOG
Bayside Melbourne.
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 10:29 Go to previous messageGo to next message
It's hungry? Razz
V8_MA61
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 10:31 Go to previous messageGo to next message
a pulley not being on straight/ too much/ not enough tension on the belt?
xl912
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 11:07 Go to previous messageGo to next message
Thanks for the suggestions
... it can't be hungry, it's had two already Wink
... Pulleys look correctly aligned, no obvious faults. The tension 'felt' right; <90º twist on longest run, around 100 Hz.
Have checked the basics. Am looking for something that may be specific to the 7MGE; moving tensioner, worn bearing/other parts.
All advice much appreciated. Feel free to suggest the basics, I may have over looked something simple (as often happens).
Robert
V8_MA61
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 11:14 Go to previous messageGo to next message
only thing ther than tension would've been crankshaft pulley movement. but this shouldnt be happening anyway..is your motor in good nic? ie no bangs, knocks or rattles?
celicaboy_2000
Lismore, NSW
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 11:17 Go to previous messageGo to next message
Tight camshafts?
Damage sprockets?
Tight oil pump?
Tight Idle pully?
xl912
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 11:22 Go to previous messageGo to next message
When the first one shredded itself, we found the crank pulley was loose and assumed that to be the cause.
This time it's still tight.
Engine is quite tired, tappet noise, bearing noise, blow-by and the usual oil leak suspects. It may well be time to replace the whole thing.
... Is the oil pump driven off the jackshaft?
Robert
V8_MA61
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 11:23 Go to previous messageGo to next message
oil pump dead? My oil pump bearings were extremely tight fit when i rebuilt my motor..and would've snapped belts had i not have worn in the bearings with a scourer.
xl912
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 11:40 Go to previous messageGo to next message
Are the oil pumps and/or bearings prone to seizure?
Are these engines expensive or difficult to do a full rebuild?
Robert
V8_MA61
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 11:50 Go to previous messageGo to next message
depends if your head is rooted Wink
xl912
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 12:01 Go to previous messageGo to next message
I suspect that it'll need a proper head job.
Are you implying that the bottom end is cheap and easy, but the head is an expensive nightmare?
Robert
V8_MA61
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 12:07 Go to previous messageGo to next message
xl912 wrote on Sun, 01 August 2004 22:01
Robert
exactly right Wink
xl912
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 12:14 Go to previous messageGo to next message
Bugger.
Thanks for the advice, much appreciated.
regards
Robert
STR8 2.8
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 12:19 Go to previous messageGo to next message
Rolling Eyes
Don't we all
xl912
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 12:21 Go to previous messageGo to next message
STR8 2.8 wrote on Sun, 01 August 2004 22:19
Rolling Eyes
Don't we all
Never mind a proper one
cseufert
Melbourne Vic
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 12:40 Go to previous messageGo to next message
umm, with regaurd to your money hungry 7M, have u tried getting a new tensioner & spring. (I know, 2 weeks from japan, still waiting on one), anyhow i would bet its the spring, mine was under tension, and was slapping around under accell, only a matter of time, and it prob would have stripped the belt teeth.
And i got the head completely done up (2 cracks welded, stud hole welded & tapped, valve grind, reseat, valve guides, shims & hot high pressure clean), new hg kit, new injector seals, throttle body gasket, double platinum NGK's and usual coolant, oil & filter change for $1200, car is like new. (all labour done by me thou)
If your bottom end if fucked thou, then prob easier to just get another engine for her.
Pic of my head after reco (Warning: HUGE pic):
http://members.optushome.com.au/cseufert1/IMG_0008 .JPG
xl912
Re: Shredded Timing Belt, 7MGE Sun, 01 August 2004 12:54 Go to previous message
Thanks. I'll have a look at the tensioner and spring.
Not sure that investing that kind of money in the head is good value for this engine.
As you suggest, it may be more cost effective to replace it.
Robert
Previous Topic:5mge - no p/s pump connected
Next Topic:running in
Current Time: Fri Nov 20 13:14:20 UTC 2026
Total time taken to generate the page: 0.012210130691528 seconds
