Toymods » Tech & Conversions » Tacho interupting igition
ta2272
Tacho interupting igition Mon, 02 August 2004 04:04 Go to next message
Had a problem when installing efi when tacho was connected it would stop it giving spark wile driving, anyone had this problem or know how i could fix it.
Jason
fade-e
Re: Tacho interupting igition Mon, 02 August 2004 06:27 Go to previous messageGo to next message
im assuming you mean rev tacho? if so then it is wiring wrong. best option is to either get wiring diagram and check it, or get auto electrician to check for you.
me personally i would get the wiring diagram and just re run it seperately. basically dont use the stock plug and re-wire it
ta2272
Re: Tacho interupting igition Mon, 02 August 2004 12:38 Go to previous messageGo to next message
The Tacho REV tacho was running of the old points dizzy but when insalling the new elec dizzy there was no mouting point on the distributor, so i mounted it on the negative of the coil,
is what you said still a recomendation.
Thanks alot fade-e
earlyrolla
Re: Tacho interupting igition Mon, 02 August 2004 12:54 Go to previous messageGo to next message
On the negative side of the coil is right.
Assuming that an electronic ignition was fitted with the EFI, these are some suggestions:
The tacho hasnt been shorted accidently and damaged internally while fitting the EFI?
The new ignition system isnt MS (multiple spark)?
Some EFI computers have a tacho output as opposed to picking up off the coil.
You could try an appropriately sized diode in the lead to the tacho if all else fails, it may help.
[Updated on: Mon, 02 August 2004 12:58]
fade-e
Re: Tacho interupting igition Mon, 02 August 2004 13:33 Go to previous message
look into what earlyrolla said but i personally would reqire the tacho and just cut the old wiring/plug used if you cant get it working right.
but i do this on the basis that i am going to get the whole car rewired properly when completely finished so not only is it right but also looks nice and neat.
also running off the coil may short the tacho cause it is supplying over 20k volts, thats why it goes on the dizzy as the condensor prevents shorting. but thats with points im no real expert with electronic dizzy.
if i saw it i would figure it out but off the top of my head not definate.
Previous Topic:Ease of / Cost of brake conversion for RA65 celica
Next Topic:Trial fitting turbo in AE82..attn: 4AGZE turbo AE82 people..please(warning:about 350kb of photos)
Current Time: Wed Nov 18 09:45:02 UTC 2026
Total time taken to generate the page: 0.0036261081695557 seconds
