Toymods » Tech & Conversions » 1jz-gte Soarer blow off valve help
tyottsoarer
Gold Coast
1jz-gte Soarer blow off valve help Mon, 02 August 2004 12:03 Go to next message
hey all
I just had my intercooler fitted along with a HKS SQ blow off valve, but i noticed that the stock blow off thing has a very large diameter line coming off the bottom of it that attaches to the compressor housing cover things for the turbos ( i know that was vague but 1jz owners should know what im talking about .. i hope) and that the bov is actually attached to the air inlet for the turbos. how in the hell does this have to be blocked off? and where do i attach the vacuum line for the new bov?
Thanks if you can help me.
Re: 1jz-gte Soarer blow off valve help Mon, 02 August 2004 22:36 Go to previous messageGo to next message
You don't have to block anything off to disable the stock BOV. Simply re-route the vacuum line (ie the one that goes to the plenum) to the high-pressure side of the turbos. That way there will always be equal pressure on both sides of the BOV so it will never open. This is what I did on my 2JZ and it works well.
tyottsoarer
Gold Coast
Re: 1jz-gte Soarer blow off valve help Tue, 03 August 2004 06:20 Go to previous messageGo to next message
Ah ok i know where the vacuum line is now ( haha nowhere cause the other valve is using it ) but where or how do i connect it to the high pressure side of the turbos, this question will probably spark a newbie alert... sorry
ChuckLandwehr
Re: 1jz-gte Soarer blow off valve help Tue, 03 August 2004 12:27 Go to previous messageGo to next message
Leave the HP line connected to the stock BOV. The stock one utilizes HP air to push the valve. Your aftermaket BOV relies soley on the vacuum line to pull the diaphram, and open the valve.
regards Chuck.
Re: 1jz-gte Soarer blow off valve help Tue, 03 August 2004 22:38 Go to previous message
tyottsoarer wrote on Tue, 03 August 2004 16:20
Just use a T-piece on any line coming off the high-pressure side of the inlet piping. This means anywhere between the compressor housings and the throttle body. I can't tell you exact locations on a 1JZ, but there must be at least one line available (ie the wastegates).
Previous Topic:lexus V8
Next Topic:5M-E Oil Sender Thread Size
Current Time: Thu Nov 19 21:08:30 UTC 2026
Total time taken to generate the page: 0.0061709880828857 seconds
