Toymods » Tech & Conversions » 5M-E Oil Sender Thread Size
ZZT231
melbourne.vic.au
5M-E Oil Sender Thread Size Mon, 02 August 2004 21:32 Go to next message
Hey All,
What is the diameter of the oil pressure sensor hole in the block?
Cheers.
._T_.
Re: 5M-E Oil Sender Thread Size Mon, 02 August 2004 22:23 Go to previous messageGo to next message
prob the same as the 4age i'd say - 1/8-28bspt
T
ZZT231
melbourne.vic.au
Re: 5M-E Oil Sender Thread Size Mon, 02 August 2004 23:56 Go to previous messageGo to next message
I require it so I can attach a Oil pressure sender, as well as the oil light switch... I just need to know the size of the thread for the T Junction.
Cheers.
[Updated on: Mon, 02 August 2004 23:56]
._T_.
Re: 5M-E Oil Sender Thread Size Tue, 03 August 2004 00:38 Go to previous messageGo to next message
so you need a t or y-piece. have them to suit toyotas. $20ea
i'm in melbourne too.
T
Re: 5M-E Oil Sender Thread Size Tue, 03 August 2004 03:16 Go to previous messageGo to next message
Hey I need one of them too (for my 18R-G), but I want to run three things off it - oil light switch, oil gauge, and turbo oil feed. Is it possible to get a 3-way adaptor or would I have to use 2 T-pieces?
._T_.
Re: 5M-E Oil Sender Thread Size Tue, 03 August 2004 04:13 Go to previous messageGo to next message
you'll have to run 2 "T"s i'm afraid - unless you happen to have a 1/8x28 bsp tap you can tap out another fititng on the t piece with....... Smile
T
Re: 5M-E Oil Sender Thread Size Tue, 03 August 2004 05:08 Go to previous messageGo to next message
Using two T pieces is no big deal I guess. Where would one purchase such items?
[Updated on: Tue, 03 August 2004 05:08]
Allan
Re: 5M-E Oil Sender Thread Size Tue, 03 August 2004 05:49 Go to previous messageGo to next message
goto an engineering place get them to make you a distribution block from some HEX bar would probably cost all of ~$50 run a hose from the engine to the distribution block and all done!
Allan
Re: 5M-E Oil Sender Thread Size Tue, 03 August 2004 06:28 Go to previous messageGo to next message
I got a distribution block made for my 5MTE using some brass hex. $50.
Just go to any hydraulic place for T pieces. Any place that sells guages will also sell adaptors.
Re: 5M-E Oil Sender Thread Size Tue, 03 August 2004 08:54 Go to previous messageGo to next message
Norbie wrote on Tue, 03 August 2004 13:16
norbie: there should be another blocked-off port just above the oil sender port (and same size/thread) or at least there in on the 18R block - i use one for oil sender, the other goes to turbo. saves having a t-peice that eventually leaks or fails from the vibration.
cheers.
Re: 5M-E Oil Sender Thread Size Tue, 03 August 2004 08:58 Go to previous messageGo to next message
cheers.
Re: 5M-E Oil Sender Thread Size Tue, 03 August 2004 22:27 Go to previous message
I wasn't aware of that... I'll have to check it out on my 18R-G when I get home. Thanks for the tip!
Previous Topic:1jz-gte Soarer blow off valve help
Next Topic:Standard comp test results for 4AGE 16V
Current Time: Thu Nov 19 22:33:33 UTC 2026
Total time taken to generate the page: 0.0049190521240234 seconds
