Toymods » Tech & Conversions » AE86 Wheel alignment settings
TRUENOAE86
AE86 Wheel alignment settings Mon, 02 August 2004 23:00 Go to next message
Im getting a wheel alignemt done today at 12pm (Tuesday 3 Aug).
Just wanting some opinions/experiences as to what the best setup is for track use(Wakefield Park).
Camber ?
Caster ?
Tow?
I'm thinking along the lines of:
-3 deg of Camber
0 deg of Tow
as much caster as I can get.
Jason
ke382TG
Re: AE86 Wheel alignment settings Tue, 03 August 2004 00:03 Go to previous message
Hey Jason,
I think I am going to have:
1.75 degrees negative camber
maximum caster that can be adjusted
0 or 0.2 degree toe in
This is how it was set last time I had an alignment but with only about 0.7 degrees negative camber.
I have roll centre adjusters to fit tonight and I have raised the front end 17mm too. I hope these two changes eliminate the bump steer that I experience in hard cornering, but I suspect I may need thicker RCA's to completely rectify this problem.
Let us know how you go with your wheel alignment and who is doing it?
Previous Topic:ST205 Water Sprayer Wiring
Next Topic:Microtech dealer
Current Time: Wed Nov 18 04:32:54 UTC 2026
Total time taken to generate the page: 0.0045671463012695 seconds
