Classifieds » Miscellaneous » 2JZGTE Wiring loom and Ignitor
Bentt
2JZGTE Wiring loom and Ignitor Mon, 02 August 2004 23:47 Go to next message
Hi Guys...
Have a complete 2JZGTE wiring loom and 2JZ ignitor for sale. I will have the auto ecu also in a little while. I hand removed them from my Aristo 2jzgte... Some of the coil plugs are slightly damaged, but these are easily replaced.
I also have a bunch of other 1jz and 2jz parts, Twins CT20 turbos, 1jz ignitor, MAP sensor's, both 1/2jz, throttle bodies, fuel rails, power steer pumps, alternator, starter, etc etc etc... All needs to be sold Smile
BAW@HVACQLD_dot_com
Ben
ed_ma61
Lost in the K hole
Re: 2JZGTE Wiring loom and Ignitor Mon, 02 August 2004 23:52 Go to previous messageGo to next message
ben, hows things looking with shipping? or was i supposed to be looking at that bit? Razz
also, what other 2jz bits do you have there? fuel rail? a more specfic list of other bits?
ed
Bentt
Re: 2JZGTE Wiring loom and Ignitor Tue, 03 August 2004 01:01 Go to previous messageGo to next message
Hey Ed
Sump. is there ready to be packaged.. I thought you were getting some money together etc? Where is it going to? I'll get some cardboard and box the sump up as neatly as I can one night this week, then we can go from there Smile
I'll be modding the 2jz fuel rail... So can't sell it, have lots of 1jz ones though Smile
2JZ stuff.
- Turbo's CT20's, with all piping oil lines, manifolds water lines etc etc etc...
- Throttle body
- power steer pump
- alternator
- auto gearbox, flex plate, convertor
- leccy master cyl
- leccy steering column
- dash etc etc etc
- A/C Compressor
- lots of little VSV's etc
acmtt
Re: 2JZGTE Wiring loom and Ignitor Tue, 03 August 2004 09:48 Go to previous messageGo to next message
Hey Ben, is the 2jz throttle body larger than the 1J?
Is it a bolt on upgrade( my favourites) Very Happy
Andrew
Bentt
Re: 2JZGTE Wiring loom and Ignitor Tue, 03 August 2004 10:17 Go to previous messageGo to next message
Andrew.. will throw some verniers across them for you tomorrow night and let you know Smile
Manny
Re: 2JZGTE Wiring loom and Ignitor Tue, 03 August 2004 11:11 Go to previous messageGo to next message
Andrew
It's ~10mm larger but not a bolt on affair.
Needs relieving of the ID of 1J plennum and studs/threads retapped or sdapter made to bolt on.
Ben
Did you get my reply about readiness for pickup?
acmtt
Re: 2JZGTE Wiring loom and Ignitor Tue, 03 August 2004 11:22 Go to previous messageGo to next message
OK then you would need a 2j plennum setup ( which probably wouldn't help anyway due to the differences?.... or a spare 1j to match port.....
How much are you after Ben? $$$$$$$
[Updated on: Tue, 03 August 2004 11:31]
acmtt
Re: 2JZGTE Wiring loom and Ignitor Tue, 03 August 2004 12:44 Go to previous messageGo to next message
Ben, did you ever get the results of your custom plennum?
[Updated on: Tue, 03 August 2004 12:44]
FUS01
Mackay
Re: 2JZGTE Wiring loom and Ignitor Tue, 03 August 2004 14:03 Go to previous messageGo to next message
PM Sent. Smile
Bentt
Re: 2JZGTE Wiring loom and Ignitor Wed, 04 August 2004 07:55 Go to previous messageGo to next message
Thanks Manny... I didn't have a box large enough at home, so I'll have to find a larger one, but if we can arrange a time, then I'll make sure it's ready Smile
I have a 1jz manifold for sale also Andrew... I can maybe adapt it on there for you if you are seriously keen.. I must mention this one has the TRC though...
No Flow figures I sold it to a chap from here, Haven't heard about it since... (Richard?)
FUS01<- if you ask Manny he might be able to tell you where he bought his coil plugs new from Smile
acmtt
Re: 2JZGTE Wiring loom and Ignitor Wed, 04 August 2004 08:25 Go to previous messageGo to next message
Ben i am not familiar with the TRC system. Does it get in the way? Can it be removed without headache and problems?
How much for the intake manifold?
How much for the throttle body?
Andrew
Bentt
Re: 2JZGTE Wiring loom and Ignitor Thu, 05 August 2004 01:41 Go to previous messageGo to next message
Andrew, I'll suss it out a bit more and determine what is actually involved before commiting to a price... Smile
TRC is the traction control butterfly, a motor sits in front of the std butterfdly driving a second butterfly(normally open) That closes the opening to the primary butterfly under traction control engagements to limit the air etc entering the engine... I can easily remove the traction motor butterfly etc and tidy teh body up a bit, but I can't bring it back to as smooth as a std non-trc throttle body...
acmtt
Re: 2JZGTE Wiring loom and Ignitor Thu, 05 August 2004 06:07 Go to previous messageGo to next message
Ben it sounds like it would be better for me to get a 2JZ TB without the TRC,(thanks for the explanation) to make it worth the effort.
Thanks anyway
Andrew
Manny
Re: 2JZGTE Wiring loom and Ignitor Thu, 05 August 2004 13:55 Go to previous messageGo to next message
Andrew
All the 2JZGTE TB's I've seen have TRC.
7M-Brisbane
Re: 2JZGTE Wiring loom and Ignitor Sun, 08 August 2004 11:58 Go to previous messageGo to next message
Ben, it's a long shot, but you know near the ignitor pack there's a tiny little resistor or something?
I need that. Can you help out?
As a side note the W58 is in the Corona now, goes for rack & pinion swap on Thursday.
[Updated on: Sun, 08 August 2004 12:02]
Bentt
Re: 2JZGTE Wiring loom and Ignitor Mon, 09 August 2004 05:22 Go to previous messageGo to next message
Leigh.t. pretty sure it's a capacitor mate... I 'may' have one... not 100% sure.. I have an ignitor and it may still be on that Smile
Finally half way there mate;) Last time I spoke you were talking 2-week turn around;) hehehe.. ohh how things blow out...
I'm slowly getting some headway with mine... Engineer was happy with his interim inspection... so just a matter of getting it complete now Smile Cages, harness', seats, Autronics, turbo's, manifolds, intercooler, radiator etc etc etc Smile
Steve-AE86
Ademelaide, SA
Re: 2JZGTE Wiring loom and Ignitor Tue, 17 August 2004 04:33 Go to previous messageGo to next message
hey mate, still got the MAP sensor?
if so, how much you want for it?
steve
Bentt
Re: 2JZGTE Wiring loom and Ignitor Tue, 17 August 2004 04:57 Go to previous message
2JZ or 1JZ Steve???
Either $75 posted...
Previous Topic:BRAND NEW DOUBLE DIN PANASONIC HEADUNIT FS
Next Topic:ST185 Group A Front Cut bits (JDM)
Current Time: Sun Oct 18 08:03:19 UTC 2026
Total time taken to generate the page: 0.074232816696167 seconds
