Toymods » Tech & Conversions » Clutch Issues - not disengaging correctly
Skip
Clutch Issues - not disengaging correctly Tue, 03 August 2004 00:02 Go to next message
After completing my conversion I quickly killed my first clutch, which, with in the car drove fine. I replaced my clutch and at the same time kept the first pressure plate but had it modified to propbably 50% more clamping load (up around 3000kg now). Ever since this my clutch has been getting worse and worse. When i drive the car around normally its alright but when i flog it my gear changes crunch, and sometimes i cannot find a gear at all i have to keep clucthing in and out until it eventually pops into a gear.
Its pretty safe to assume that my clutch is not disengaging all the way. Last night i noticed brake fluid leaking from the master cylinder push rod boot inside the car. Could a screwed seal in the master be the problem? Bypassing pressure? Or maybe will I have to increase the length of the master pushrod for more clutch travel?
joecoolmk2
Re: Clutch Issues - not disengaging correctly Tue, 03 August 2004 01:55 Go to previous messageGo to next message
the reason is obviously that you've not got enough pressure because you're losing fluid. follow the trail of brake fluid to the leak and investigate it. is your reservoir full? if it's low there's not enough fluid to engage the clutch to change gears, which means it's leaking pretty bad. the reason it's leaking is because the hydraulic system has to work harder and it wasn't made to. you need to upgrade it.
ra23celica
Re: Clutch Issues - not disengaging correctly Tue, 03 August 2004 02:09 Go to previous messageGo to next message
And if you have this same problem but are not suffering any fluid leak, does that mean I need to upgrade to a bigger clutch MC ? Or is it an adjustment problem ?
Thanks,
Mitch.
joecoolmk2
Re: Clutch Issues - not disengaging correctly Tue, 03 August 2004 02:27 Go to previous messageGo to next message
probably both. check your pedal "play". the amount of free movement, it should be less than 2cm.
Skip
Re: Clutch Issues - not disengaging correctly Tue, 03 August 2004 04:45 Go to previous messageGo to next message
My resivour is not losing much oil, but this is because I havent been driving the car. Its coming out of the little boot that covers the push rod, regardless ill have to remove my master cylinder. Is it possible to buy a rebuild kit, or am i completely undergunned now and have to upgrade to a better master cylinder?
joecoolmk2
Re: Clutch Issues - not disengaging correctly Tue, 03 August 2004 10:35 Go to previous messageGo to next message
sounds like the bushes in the MC have given in. you could replace them, i don't know the part numbers, or where YOU could get them, i'm in tassie. you could just get a better, bigger master cylinder instead of fartarsing around with that one when it'll probly happen again anyway. you want a master cylinder that's got a bigger diameter than the one you've got. it has to be the same stroke or longer, try to get one the same so you're pedal movement's the same. i guess you could bore the one you've got out a bit and put a suitable new piston in it.
Pewee
Re: Clutch Issues - not disengaging correctly Tue, 03 August 2004 11:08 Go to previous messageGo to next message
did you reatain the same clutch slave cylinder? as was originally matched with the master or did it get changed in the conversion?
if it's the original one DON'T change the bore size of the master cylinder as this will make the slave cylinder overthrough in stroke and will probably pop the piston out or bend the clutch fork.
pull off both the master and the slave cylinder and take them a brake or clutch workshop.
they will check the condition of the bores and match up either the right rebuild kit or suitable replacement master cylinder.
the reason it probably blew was it's old and the brake fluid on the rubber seal over the years has made it go hard and crack and then leak fluid past it.
a common problem on all cars.
Skip
Re: Clutch Issues - not disengaging correctly Tue, 03 August 2004 23:39 Go to previous messageGo to next message
No I have a brand new slave cylinder, dellow supplied it along with the bellhousing, clutch fork etc. As i said at first it worked fine but when i upped the clamping force it works like crap now. mmm might have to make a trip to the clutch expert.
Maurice c
Re: Clutch Issues - not disengaging correctly Tue, 03 August 2004 23:59 Go to previous messageGo to next message
Sounds like a master cylinder seal problem to me. I'd rebuild it, or better replace it with a new one and see how it lasts before going anywhere.
Re: Clutch Issues - not disengaging correctly Wed, 04 August 2004 00:20 Go to previous messageGo to next message
When the pressure plate was modded, I'm also guessing the pivot point was altered, meaning a longer stroke is needed to diesngage it properly. Fix up the hydraulics first, and if there's still an issue, then it's time to play around with the clutch... But crook hydraulics will definately cause this problem - my old heap I drive around with has the same issue, crook MC and doesnt always like changing gears...
Pewee
Re: Clutch Issues - not disengaging correctly Wed, 04 August 2004 09:25 Go to previous messageGo to next message
yeh as i said the m/c seals where probably well on the way out and when you put the extra load required to relaese the clutch the seals couldn't handle it.
just be carefull cause mismatched bore sizes will cause you more problems than you want.
Not that any problems are good. haha
thanks Nathan
Skip
Re: Clutch Issues - not disengaging correctly Thu, 05 August 2004 04:45 Go to previous messageGo to next message
No worries, thanks for the advice ill just put a rebuild kit through it. Do you guys know where the best place to source a kit would be from?
wagonist
Toymods Club Treasurer
Re: Clutch Issues - not disengaging correctly Thu, 05 August 2004 05:43 Go to previous messageGo to next message
On a slightly different tack, if the thrust bearing wasn't the right thickness, I'm guessing this could cause the clutch to not properly disengage too?
lumpy
Adelaide, SA
Re: Clutch Issues - not disengaging correctly Thu, 05 August 2004 07:12 Go to previous messageGo to next message
Skip wrote on Thu, 05 August 2004 14:15
I'm guessing it's still the toyota master cylinder? I bought a rebuild kit for mine from toyota. When you take it out you could also get the bore sleeved in stainless steel for extra longevity (or if it's scored). This is usually pretty cheap from a brake/clutch place.
lumpy
Adelaide, SA
stupid double post.
[Updated on: Thu, 05 August 2004 07:13]
Skip
Re: Clutch Issues - not disengaging correctly Thu, 05 August 2004 08:55 Go to previous messageGo to next message
Thrust bearing thickness has SFA to do with it. I have an adjustable pushrod on the slave and pivot ball in the bellhousing, so i can set it wherever i like. Obviously just not getting enough stroke in the slave cause the master is screwed.
Yer its still the standard Bundera master.
Skip
Re: Clutch Issues - not disengaging correctly Fri, 13 August 2004 01:43 Go to previous messageGo to next message
Problem solvered.
$15 seal kit and a bit of skin off the knuckles, didnt even have to hone it. Clutch works fine now, pedal effort has actually reduced a bit too.
RobST162
Re: Clutch Issues - not disengaging correctly Mon, 30 August 2004 05:28 Go to previous messageGo to next message
hey Skip
I just changed my box and it feels like the clutch is not completely disengaging at the moment
I just had a look at my master and noticed a veyr small amount of fluid around the boot.
This MC is only maybe 2 years old, I was just wondering how much yours was leaking when you resealed it, and where you got your kit from?
Thanks heaps!
Rob Smile
Skip
Re: Clutch Issues - not disengaging correctly Mon, 30 August 2004 05:57 Go to previous message
Yeah my master had fluid around from out of the boot too, it was running down my floor mat. I got the kit from REPCO, was a PBR one. ITs piece of piss to rebuild, the hardest part probably is getting the rubber seals onto the piston thingy Smile
Previous Topic:Removing RA28 side windows
Next Topic:Tacho Shorting out igition system
Current Time: Sat Oct 17 08:07:45 UTC 2026
Total time taken to generate the page: 0.049429893493652 seconds
