Toymods » Tech & Conversions » oil pressure on 3SGTE
SXY184
oil pressure on 3SGTE Tue, 03 August 2004 08:27 Go to next message
hey all, jus a quick question, whats the stock oil pressure for a gen 2 3SGTE at idle ?
any help , many thanks!
510rob
Vancouver
Re: oil pressure on 3SGTE Tue, 03 August 2004 10:15 Go to previous messageGo to next message
http://www.mr2-tech.com/bgb/mechanical/volume1/lub rication_system/3.htm
Oil pressure at idling = "4.3psi or more" (suprisingly low!!!)
Oil pressure at 3000rpm = "36psi - 71psi" (pretty wide range!!!)
Joshstix
Toymods Vice President
Re: oil pressure on 3SGTE Wed, 04 August 2004 02:15 Go to previous message
The pressure take off point is very high on the engine and a long way fromt the pump sot there is a lot of pressure lost in the system before getting to the sender.
This compares to an engine like the 4AGE where the pressure sender is right after the pump, which will read higher due to there being no system loss between the pump and sender.
Previous Topic:18RG timing chains
Next Topic:bending rear axle for negative camber
Current Time: Thu Nov 19 19:12:30 UTC 2026
Total time taken to generate the page: 0.0058481693267822 seconds
