Toymods » Tech & Conversions » urgent: 1G series gearbox info needed
bunny
North Sydney
icon9.gif  urgent: 1G series gearbox info needed Wed, 22 May 2002 11:16 Go to next message
having troubble sourcing a cheap supra 5 speed drive line for my 1GGTE conversion my question is:
i have found a 1G-EU GA61 supra + a cheap auto front cut can i put the driveline + gearbox from that onto my MA 61 and put the 1G GTE in front of that?
stradlater
Arthurs Creek, Victoria
Re: urgent: 1G series gearbox info needed Wed, 22 May 2002 11:30 Go to previous messageGo to next message
Ok
Explain that one again.
Basically, yes you are right, you can put a supra 5 speed behind a 1g-gte provided you have the correct bellhousing.
Do you?
As for this other engine. the 1g-gue that you have found. Is it an auto or a manual?
Also, you will need to mess around with the fly wheel setup between whether it's a manual or an auto.
But yes it is possible to put a supra 5 speed behind a 1g-gte, and I even have the clutch here for one.
bunny
North Sydney
Re: urgent: 1G series gearbox info needed Wed, 22 May 2002 12:07 Go to previous messageGo to next message
what i need to know is
can i replace the auto on the 1GGTE with the old auto off a 1G-EU which is out of a GA 61 supra
ie making my 1GGTE MA61 supra an automatic
( it is much cheaper to make an auto than a manual)
Re: urgent: 1G series gearbox info needed Wed, 22 May 2002 12:26 Go to previous messageGo to next message
Yeah, its probably doable...but why dont you just use the auto from the front cut..???
The auto from the GA61 will be a dodgy 3 speed with overdrive.
stradlater
Re: urgent: 1G series gearbox info needed Thu, 23 May 2002 03:05 Go to previous messageGo to next message
yes, I would suggest using the auto out of the front cut too
Re: urgent: 1G series gearbox info needed Thu, 23 May 2002 08:18 Go to previous messageGo to next message
justcallmefrank wrote on Wed, 22 May 2002 10:26 PM
Mk2 Supra's come with a 4-speed auto transmission... not a 3-speed with overdrive. Yes, 4th gear is overdriven, but it's integrated into the box - therefore it is a 4-speed box.
I agree though, use the auto from the front cut as it will probably be stronger for turbo duty.
Re: urgent: 1G series gearbox info needed Thu, 23 May 2002 08:28 Go to previous messageGo to next message
Are you sure all the boxes are the same? I'm pretty sure this Mk2 Celica XX I was looking at had the 3-speed I was describing, it had a 1GEU and a bloody T-series IRS. It was a very poverty pack Mk2.
Re: urgent: 1G series gearbox info needed Thu, 23 May 2002 08:29 Go to previous messageGo to next message
By three speed with O/D I mean it had 3 speeds and an overdrive button...
Re: urgent: 1G series gearbox info needed Thu, 23 May 2002 10:00 Go to previous messageGo to next message
3-speed with overdrive implies that it's a 3-speed box with an external overdrive unit. Some older auto boxes were set up this way, but not the one in the Supra - it's a proper 4-speed.
The overdrive button on the Supra simply activates a solenoid inside the box which disables 4th gear.
Re: urgent: 1G series gearbox info needed Thu, 23 May 2002 10:07 Go to previous messageGo to next message
This may seem like a stupid question, but why would you want to disable a gear?
Re: urgent: 1G series gearbox info needed Fri, 24 May 2002 05:54 Go to previous message
I used to hit the overdrive disable button in my Supra all the time. When you're cruising around the suburbs at 60km/h or less, you don't really want the trans shifting into 4th all the time. As soon as you want to accelerate anywhere it has to kick back to 3rd, then when you're done it slips into 4th again... so it's hunting back and forth all the time, which can get annoying. The solution is to disable 4th, and just cruise around in 3rd!
Previous Topic:4k + 32/36 DGV Weber
Next Topic:Backyard Operation
Current Time: Mon Nov 2 16:38:40 UTC 2026
Total time taken to generate the page: 0.078711986541748 seconds
