Toymods » Tech & Conversions » installing water temp gauge
Satoshi
installing water temp gauge Tue, 03 August 2004 13:33 Go to next message
i got a water temp (electrical) gauge that i wanna install into my 4ag...how do i go a about doing it??
Satoshi
Re: installing water temp gauge Sat, 07 August 2004 19:54 Go to previous messageGo to next message
bumpy me
is it just plug and play?
or some modification needs to be done..
another gauge i'm thinking about is oil temp...
plssssssssssssssssssssssssssss help
Cyber-punk
Brisbane, QLD
Re: installing water temp gauge Sun, 08 August 2004 01:40 Go to previous messageGo to next message
did it not come with some sort of instruction?
i assume you attach the sender unit thingo to somewhere it can sence water temp. then attach the wires from that to your gauge inside your vehicle
CLG
Perth, Western Australia
Re: installing water temp gauge Sun, 08 August 2004 02:46 Go to previous messageGo to next message
Pretty simple in the scheme of things. One point to address is the pickup sensor positioning - for the most accurate results, you want the sensor in the water flow path, not shrouded in an end, or recess, where water is idle and stalls around the sensor.
SW20R
Re: installing water temp gauge Fri, 29 July 2005 14:18 Go to previous message
Water temp to be installed inline with the coolant flow. easiest option is buy a hose adaptor and hook it up near the front radiator pipe.
Oil temp - can be fitted to the oil cooler adpator
http://trdparts.jp/english/image/meterlink_fitting.jpg
http://www.miata.net/garage/GaugeInstall/
Previous Topic:F Series Diff into KE35
Next Topic:engineer in canberra
Current Time: Sat Nov 21 04:04:26 UTC 2026
Total time taken to generate the page: 0.003993034362793 seconds
