Toymods » Tech & Conversions » 7M AFM and Injectors
MR 1JZ
7M AFM and Injectors Wed, 04 August 2004 05:19 Go to next message
Hey im looking at putting a 7MGTE AFM and Injectors onto my 1GGTE as i have heard that this will raise the level at which boost cut kicks in, is this true and is it worh doing the injectors as well, will they both fit straight in??
Bugman
Re: 7M AFM and Injectors Wed, 04 August 2004 06:01 Go to previous messageGo to next message
why?!?
run 15psi and be happy.
CrAiGzEE
south of the big smoke
Re: 7M AFM and Injectors Wed, 04 August 2004 06:04 Go to previous messageGo to next message
you cant run a 7m afm! they aint the same as the 1g, they dont use the flap system
umm NO
Quote:
is this true
umm no
umm no
umm yes for injectors
improvedae86
Re: 7M AFM and Injectors Wed, 04 August 2004 06:20 Go to previous messageGo to next message
Maybe this has been covered here :
http://forums.toymods.org.au/index.php?t=msg&t h=41111&start=0&rid=1935&S=71f5a781ca9 6c56bc4e46d8878790238
Laughing
MR 1JZ
Re: 7M AFM and Injectors Wed, 04 August 2004 07:38 Go to previous messageGo to next message
Bugman wrote on Wed, 04 August 2004 15:31
why?!?
I can run 15PSI without fuel cut, the dyno guy said 11 maximum, what a tool!
Awesome.
lumpy
Adelaide, SA
Re: 7M AFM and Injectors Wed, 04 August 2004 07:52 Go to previous messageGo to next message
MR 1GGTE wrote on Wed, 04 August 2004 14:49
Perhpas they meant the 7M-GE AFM - that is a vane/flap type and 7M-GE injectors. I'm not sure if it plugs in/bolts on or if there is any performance increase from it though....
MR 1JZ
Re: 7M AFM and Injectors Wed, 04 August 2004 08:12 Go to previous messageGo to next message
cheers, for that, dont you just hate people that are full of shit...
I have heard things about the 1UZ AFM's are they a worthwhile upgrade for increasing the boost cut level???
Re: 7M AFM and Injectors Wed, 04 August 2004 22:54 Go to previous message
The 1UZ uses a MAF sensor, same as the 7M-GTE (but larger). It's commonly used as an upgrade for 7M-GTE's but won't work as a replacement for a flapper-type AFM as used on the 1G.
Previous Topic:5M-E stalling
Next Topic:pros and cons of lightened flywheel? ae82 related
Current Time: Sun Nov 1 06:00:01 UTC 2026
Total time taken to generate the page: 0.0060319900512695 seconds
