Classifieds » Parts Wanted » 18R-G
TRD_Celica
Hobart
18R-G Wed, 04 August 2004 11:20 Go to next message
G'day all
I am looking for an 18R-G. hopefully one that is in working condition and one that is not to fucked!!! I have got an RA60 so i want to ditch the ol' 21R-C. Also anyone who knows about them would an 18R hook upto the RA60 gearbox ?? hmmm
Hope to hear from someone who can offer me somethign soon
brett_celicacoupe
townsville NQLD
Re: 18R-G Thu, 05 August 2004 09:33 Go to previous messageGo to next message
gday mate,
i dont have a engine to sell but im really sure that all R series engines are compatible. ie. are all interchangeable between gearboxes that house R engines. the only thing that you would have to modify is maybe some electrics.
i have an ra40 which im doin up, and i got the 18r-gu. cost me $100 Very Happy
people100
Rocklea qld
Re: 18R-G Thu, 05 August 2004 10:52 Go to previous messageGo to next message
a 18rg wont bolt straight in. In most cases a front sump from an early corona will be needed and some engine mount modifications will also be needed. As for gearbox it will bolt up but possible radiator hoses will be different.If u overcome these problems then it should be a good swap.
TRD_Celica
Hobart
Re: 18R-G Thu, 05 August 2004 11:24 Go to previous messageGo to next message
hmm will these parts be easy to come by ? Is that the only major problems with this engine or is there going to be some nasty surprise when i get it ? Wat is the problem with the existing sump ? is the crossmember in the way ? Wat year corona or model corona do you surgest?
people100
Rocklea qld
Re: 18R-G Fri, 06 August 2004 10:03 Go to previous messageGo to next message
Thats all the main parts u will need. most of all is the stuffing around on the crossmember mods and running new rad hoses or mounting a new rad. Parts are as easy to come by as most others u just pay more for these. Sump is from a 78ish rt104/118 coronas but u need to use your sump id be guessing. U could see if a ra40 crossmember will fit and if so you can use a mid sump which come on most 18r's these days.
TRD_Celica
Hobart
Re: 18R-G Fri, 06 August 2004 22:49 Go to previous messageGo to next message
So your surgesting either, a new crossmember from an RA40 or the Sump from either the 21R or the old skool corona? Would an 18RC sump fit the block, also wat sort of block is the corona sump off ? Engine mounts are no problems and a radiator hose shouldn't be the hardest either. Could i use the stock radiator (21R) i got at the moment or do u think it won't b enough ?
people100
Rocklea qld
Re: 18R-G Sat, 07 August 2004 04:03 Go to previous messageGo to next message
U use a sump from a 18rc out of a corona. all 18r sumps are interchangable but not 21/22r sumps. Dont just go buying a ra40 crossmember. Im only suggesting it may fit due to its a A series chassis. Your rad will be good enough solong as you can run hoses nicely. If the ra40 crossmember fits you will most likely be able to just reuse the sump that u get on the engine(whats the engine coming out of anyway)
TRD_Celica
Hobart
Re: 18R-G Sat, 07 August 2004 08:44 Go to previous messageGo to next message
I dunno wat it's from ?? some guy is selling it for $600 and i thought i sounded cool and all my mates reckon 18R-G's bloody cain so i will put it in and take all those VL's and VN's getting around Wink
CelicaRA45
nth ringwood, Victoria
Re: 18R-G Sat, 07 August 2004 10:05 Go to previous messageGo to next message
cant use the ra40 xmember as it hasnt got mounts for the rackto fit also it wouldnt bolt up anyhow
people100
Rocklea qld
Re: 18R-G Sat, 07 August 2004 10:29 Go to previous messageGo to next message
i thought about the rack not fitting after i posted. Sorry and i just thought possible since all a series chassis then member might fit but i wasnt holding my breath.
CelicaRA45
Re: 18R-G Sat, 07 August 2004 10:32 Go to previous message
the ra40 will only go into TA23 RA 23 and RA 40s celicas and RT 132 series coronas as well as they have the same skirt and rails
Previous Topic:WTB - 4AGZE LSD driveshaft
Next Topic:WTB JZA80 stock front bar for RZ and RZ side skirts and REAR pods
Current Time: Thu Oct 29 16:57:14 UTC 2026
Total time taken to generate the page: 0.12161588668823 seconds
