Toymods » Tech & Conversions » Stock 2T to 2TG: Possible?
The Inflamable Hulk
Brisbane, Queensland
Stock 2T to 2TG: Possible? Wed, 04 August 2004 12:39 Go to next message
Howdy.
is it possible to convert a stock 2T to a 2TG? I've heard that they use the same bottom end. Also heard that mods to the oil system are needed too: but what?
AND... I know my little 2T is a single cam (mounted on side I think), but if I change the head to the twin cam head does that mean that I have to alter that part of the engine to accomodate the extra cam?
Very confused.......HELP!!
peewee
adelaide
Re: Stock 2T to 2TG: Possible? Wed, 04 August 2004 14:26 Go to previous messageGo to next message
yes you can put a 2tg head on a 2t single cam block.
there is a big thread of a compilation of all the information about these motors floating around.
i can't really remember off the top of my head what you have to do, but yes you do have to change something on how the oil flows. i guess that wasn't really that much help, but better than just linking to search........
Re: Stock 2T to 2TG: Possible? Wed, 04 August 2004 23:00 Go to previous messageGo to next message
Yes it can be done, but you have to swap a whole lot more than just the head to make it work. In fact you need so many 2T-G specific parts you're much better off just buying a complete 2T-G and swapping it in.
ke382TG
Re: Stock 2T to 2TG: Possible? Wed, 04 August 2004 23:37 Go to previous messageGo to next message
Many years ago when I cracked the block on my 2TG I sourced a 2T block and rebuilt the 2TG engine around that.
The only mod necessary was to block off the oil galleries that fed oil to the bearings where the 2T cam was located in the block. This was done by removing the bearings and then having them pressed back in with the bearings oil hole offest to the oil hole in the block.
The only other thing I can think of was to use a blanking plate to cover where the 2T had its mechanical fuel pump mounted.
Apart from that it was all a straight swap. This setup ran great for well over a 100 000km.
But yeah use ALL 2TG stuff and only 2T block and crank bearing caps.
I am assuming you are only trying to do this so that you can keep your engine number the same by using your existing 2T block??
The Inflamable Hulk
Re: Stock 2T to 2TG: Possible? Thu, 05 August 2004 02:49 Go to previous message
Thanx guys.
I just wanted to do what was easiest on my wallet.
I've so many 2Tg Heads for sale and wondered if they would be an easy fit.
I guess I'll try find a complete 2TG.
Thanx again.
Previous Topic:ke30 headlamps
Next Topic:Indepedent rear end sprinter?
Current Time: Sun Nov 22 04:27:05 UTC 2026
Total time taken to generate the page: 0.0040819644927979 seconds
