Toymods » Tech & Conversions » Mild 20v - what do u reckon?
*rivmasta*
Mild 20v - what do u reckon? Thu, 05 August 2004 04:17 Go to next message
The rebuild of the 20v for the racecar will consist of:
bottom end: hot tank, shave head & block, thin gasket (any suggestions?) new rings & bearings.
Top end: 3 way valve job, polished chambers, burr removal of ports - but not polished, cams with approx 20deg more duration (any suggestions???) cam verniers to tune them right, leave the throttle bodies alone.
Extras: Take the EMS and coil packs off the 16v and put them onthe 20v to run distributorless, GZE dizzy pickup for signal, stock extractors to 2.75" to 3.25" after collector - resonator only, no muffler. Dyno to sort out cams as well as timing & fuel. soft cut at 8400, hard cut at 8600.
Its going into an offroad buggy weighing in at about 870kg dry. We need a fair amout of mid range grunt to pull out of tight corners on the dirt, hence no wild cams. It'll be an engine for national races - up to 500km per race at finke, griffith, goodiwindi etc.
Does this sound like a reasonably powered & reliable setup for a 20v? any comments or suggestions would be really appreciated!!!
Johnny
Sydney, OZ
Re: Mild 20v - what do u reckon? Thu, 05 August 2004 06:24 Go to previous messageGo to next message
Ring Dave flood @ premier auto center 98321650.
The 20V setup we are developing for rally consists of similar spec cams verniers as well, ported head, no valve angles, 20V dizzy(no need to change this), GZE coils, and forge pistons, standard metal shim H/Gasket, standard throttles with ram tubes, still with VVT hooked up, custom manifold. A Similar setup with large cams is making 148Hp at the wheels in a IP car and haven't played with cam timing yet. This is the fifth engine built for this car (IP) previous was 130Hp using standard internals and only playing around with head, cams and exhuast.....
*rivmasta*
Re: Mild 20v - what do u reckon? Thu, 05 August 2004 06:54 Go to previous messageGo to next message
They're in Mt Druitt arent they?
What ECU are you running?
Any other suggestions for the engine???
Flogbag
Sydney (Campbelltown...!)
Re: Mild 20v - what do u reckon? Thu, 05 August 2004 07:26 Go to previous messageGo to next message
do you know if premier has tuned any stock 20v's with aftermarket computers eg. microtech ltx8 and if so wat kinda output they get out of them?
Johnny
Sydney, OZ
Re: Mild 20v - what do u reckon? Thu, 05 August 2004 12:52 Go to previous messageGo to next message
Yep
I run an Autronic, The starlet runs an M800 Motec, as will my newie.(better data logging)
Get a Vtec or 2ZZGE, these get down and boogie for an N/A engines Laughing ... being more serious, Dave's better to talk to.
100-110hp
*rivmasta*
Re: Mild 20v - what do u reckon? Fri, 06 August 2004 00:22 Go to previous messageGo to next message
Hmmm... Motec.... Im good mates with billy croft - he dyno's our car for us. I love his office, so full of fun toys! But EMS I can afford...
I know a guy with a stock 20v with the only changes being induction and exhuast and he got 112 at the treads on 30" mud tyres. It was an import engine which he didnt even take the rocker covers off!
*rivmasta*
Re: Mild 20v - what do u reckon?*** Cheap place to buy cams?? Mon, 09 August 2004 05:51 Go to previous messageGo to next message
Anyone have a suggestion as to where is a good place in Sydney to buy cams & adjustable cam gears???
Johnny
Sydney, OZ
Re: Mild 20v - what do u reckon?*** Cheap place to buy cams?? Mon, 09 August 2004 07:16 Go to previous message
Not in Sydney... Ballina Mark Yager
Previous Topic:mz20 soarer unknown button!! , need help
Next Topic:oil catch can
Current Time: Wed Nov 4 13:47:56 UTC 2026
Total time taken to generate the page: 0.10532903671265 seconds
