Toymods » Tech & Conversions » rego on my ms85
Bradelz
Tamworth
rego on my ms85 Thu, 05 August 2004 06:12 Go to next message
Hey Guys,
You probably all know about my power steering problem and it's getting rego soon and i'd like to take off what ever is broken and try to get my old man to fix it or take it somewhere to get it fixed, i was just wondering what part exactly do i take off the power steering pump or the steering rack? And what do i look for? I think i posted something about my power steering but never really got a good response in terms of what to do. And if anybody on here has 2 oringinal ms85 hubcaps i will buy and i also need the long metal strip that goes down the side at the bottom i will buy if any one has these. the car should go in for rego around october. Well hopefully somebody can help me out as im still learning
Brad Smile
Re: rego on my ms85 Thu, 05 August 2004 06:23 Go to previous messageGo to next message
Brad, where is the fluid leaking from - the PS pump (bolted to the engine and has a pulley) or from the steering box (connected to your steering wheel by way of a column)? It should be easy to tell - they are 1 metre apart.
Invariably they leak because a seal or two has failed, but you might be lucky and the leak may just be due to a loose hose. Like I suggested in my PM response, you need to clean the area to establish where the leak is from. If you determine the leak is from one of the seals, then you need to remove the PS box and replace the seals. The seals are readily available from any bearing shop and should set you back $10-15.
The steering box is connected to 4 things:
1) the chassis
2) the steering column
3) the pitman arm, and
4) the power steering lines.
Undo all of these and the box should fall out.
It is possible to replace the front seal on the power steering pump without removing the pump.
[Updated on: Thu, 05 August 2004 06:23]
Bradelz
Tamworth
Re: rego on my ms85 Thu, 05 August 2004 07:15 Go to previous messageGo to next message
Thanks alot dude your've helped out a million i think the leak is coming out of the pipe down near the exhaust pipe because it leaked onto it and created smoke. I havent really had a good look will on the weekend. Once again thanks dude your a big help
Brad
Bradelz
Tamworth
Re: rego on my ms85 Sat, 07 August 2004 08:30 Go to previous message
Update.
Got the steering box out havent had a look at it yet. Although i found my fuel pump was leaking fuel so i took it out, am going to get one from the wreckers. Where should i look on the steering box for problems?
brad
Previous Topic:Diagnosing a dead alternator (MA61 / 5mge)
Next Topic:urethane engine mounts
Current Time: Fri Nov 20 05:18:49 UTC 2026
Total time taken to generate the page: 0.0056531429290771 seconds
