Toymods » Tech & Conversions » Diesel like sound when cold MX83
mal sempf
Ipswich
icon9.gif  Diesel like sound when cold MX83 Sun, 15 September 2002 07:19 Go to next message
Gday all,
Am a newbie to this forum..thanks for any/all help/ideas.
I bought a 92 MX83 Grande in Nov99 with 72000km from Toyota dealer. Elderly gent ill, didn't drive it for 18 months...good I thought. Started burning oil 1 ltr 3000km. Took it to Toyota, they repaired it, stuck ring in piston. Re ringed, bearings, head reconditioned ($3000) at 116000km. Service book mostly up to date before my purchase. 122000km now sounds like a diesel when cold, mostly fine when warm but occasionly has a tappet like sound when hot. Toyota say that they reckon it is a cracked piston but will not know until pulled apart, same money again and that warrantly only valid if it a part they fixed, funnily the pistons hold the rings. It seems strange to me that the piston would all of a sudden get cracked. This sucks. Any ideas
Mal
mal sempf
Ipswich
Re: Diesel like sound when cold MX83 Sun, 15 September 2002 22:01 Go to previous messageGo to next message
Further to my initial... Does Toyotas diagnosis sound like it could be correct. The engine is much noisier at 1800 revs and actually has a slight pulsating vibration eminating to the cab. I know I can get a replacement imported engine for $2000 fitted, but would rather keep it the way it is (engine running properly that is)
thanks Mal
[Updated on: Sun, 15 September 2002 22:10]
jza70-mel
Perth WA
Re: Diesel like sound when cold MX83 Mon, 16 September 2002 03:55 Go to previous messageGo to next message
Detonation at part throttle when cold?
Corvid
Re: Diesel like sound when cold MX83 Mon, 16 September 2002 04:02 Go to previous messageGo to next message
Yeh that sux man...
Umm.. To me.. a freind had a 7m in a supra.. Sounds EXACTLY the same as what your getting.. Sounds to me like the big end bearing is gone. Big and costly job to fix. I would seriously recommend buying an import motor and fitting it.
Friend just got his motor for $750, All we did was change the loom over to the new motor.. Ready to drop back in.. Problem solved hopefully..
But yeh.. hehhe funny you said sounds deisel.. cause i used to call his the Diesel Supra! Smile
Re: Diesel like sound when cold MX83 Mon, 16 September 2002 04:20 Go to previous messageGo to next message
Yep, M series engines are good at doing this sort of thing. I had it happen to me twice. Sad
frebbles
Re: Diesel like sound when cold MX83 Mon, 16 September 2002 06:43 Go to previous messageGo to next message
Mine's rough at startup, I baby it until it's warm, and it goes a lot quieter, however free revving the engine sounds fricking noisy...The unfortunate thing is that the mechanic told me it was probably the big end too...although my engine has done 340,000km/s...only a head recondition and head gasket of course...
Rolling Eyes
mal sempf
Ipswich
Re: Diesel like sound when cold MX83 Mon, 16 September 2002 08:46 Go to previous messageGo to next message
Thanks for the information. If it is the big end bearing, how long will it go for before finally collapsing. Interestingly the bearings were replaced at rebuild (supposedly). If 7M engines are famous for this type of thing, is there a better alternative engine. thanks Mal
inertia
Re: Diesel like sound when cold MX83 Mon, 16 September 2002 08:53 Go to previous messageGo to next message
mal sempf wrote on Mon, 16 September 2002 18:46
1JZ-GE 2.5l Twin Cam EFi inline 6
2JZ-GE 3.0l Twin Cam EFi inline 6
1UZ-FE 4.0l Quad Cam EFi vee 8
1JZ-GTE 2.5l Twin Cam Twin Turbo EFi inline 6
2JZ-GTE 3.0l Twin Cam Twin Turbo EFi inline 6
biased99
Re: Diesel like sound when cold MX83 Mon, 16 September 2002 08:55 Go to previous messageGo to next message
Of course there is...a 1UZ-FE!
stevevp
Brisbane Qld
Re: Diesel like sound when cold MX83 Mon, 16 September 2002 10:24 Go to previous messageGo to next message
If its a tinny sound and it misfires it could be a sticking valve or a leaking hydraulic adjuster on one of the valves in the cyl head. the oil galleries feeding the cams tend to block up with crud. How long since the last oil change?
Does your oil light go out straight away?
Mine does it occasionally ,usually around service time or if i forget to check the oil levels.
Take it somewhere else and get a second opinion. Even if its another Toyota dealer.
big end bearings usually make the most noise when driving under load , and its a deep knock rather than a tinny noise.
Biased99 and Inertia, are you guys swap happy or what! Very Happy
[Updated on: Mon, 16 September 2002 10:25]
inertia
Re: Diesel like sound when cold MX83 Mon, 16 September 2002 14:51 Go to previous messageGo to next message
stevevp wrote on Mon, 16 September 2002 20:24
Not really, the man asked a valid questions, and I gave what I thought was a valid answer Laughing
Mmmm 1UZ-FE Cool
Opps, I mean, only if it is necessary!
I have stinged on a 4AG conversion in my AE92 for ages and it has cost me or my dad over 3.5g's in fixin the farkin thing up, now I am in a better financial position, if it screws up again, something nice an reliable is going it.
biased99
Re: Diesel like sound when cold MX83 Tue, 17 September 2002 04:25 Go to previous messageGo to next message
In all honesty, I'm only promoting the 1UZ because I'm doing the same thing into the same car...and of course it's a lot more reliable than the 7M!
As for being swap-happy, this is definitely the last time! Smile
(But it will be worth it when finished!!)
stevevp
Brisbane Qld
icon14.gif  Re: Diesel like sound when cold MX83 Tue, 17 September 2002 10:06 Go to previous message
Don't forget photos when you are finished.
Previous Topic:1JZ chaser engine wiring diag. anyone got one?
Next Topic:2JZ spigot bearing
Current Time: Thu Oct 15 22:51:03 UTC 2026
Total time taken to generate the page: 0.044629096984863 seconds
