Toymods » Tech & Conversions » 5MGE is teh ghey
STR8 2.8
5MGE is teh ghey Thu, 05 August 2004 07:45 Go to next message
just installed a 5me harness to replace the microtech that "was running it".
Started the engine and it blows plumes and plumes of white/brownish smoke.
I have just put the intake and throttle body ect back on after cleaning them out and a little bit of paint.
Plugs are coated in fuel (just replaced them).
When i remove the EFI fuse it starts ok and seems to run reasonably.
Any ideas?
Re: 5MGE is teh ghey Thu, 05 August 2004 07:49 Go to previous messageGo to next message
What is/are the problem/s?
STR8 2.8
Re: 5MGE is teh ghey Thu, 05 August 2004 08:03 Go to previous messageGo to next message
ah that it blows lotsa smoke, and seems to be overfuelling to the nth degree
lilcrash
ipswich queensland
Re: 5MGE is teh ghey Thu, 05 August 2004 08:29 Go to previous messageGo to next message
sounds like my 2tgeu
if sum one knows wat it is can they tell me too please, il probly keep watching this thread neways
Re: 5MGE is teh ghey Thu, 05 August 2004 09:02 Go to previous messageGo to next message
Has anyone played with the AFM that you know of?
STR8 2.8
Re: 5MGE is teh ghey Thu, 05 August 2004 09:29 Go to previous messageGo to next message
nope, ran fine on the old engine.
on a side note where would i get gaskets (intake chamber, throttle and cold start injector) for hte 5mge, do toyota still carry gaskets for such old engines?
Re: 5MGE is teh ghey Thu, 05 August 2004 09:38 Go to previous messageGo to next message
You suggest it is running rich, yet it ran perfectly before.
I would suggest you have wired something up strangely (or missed something altogether).
I would suggest looking at how you have wired up the water temp sensor, the cold start injector and the CSI switch. Make sure the CSI is hooked up to the starter power and not the ignition power. Once it is running, unplug the CSI and see what happens. If the water temp sensor is not connected the engine will run rich.
I am also assuming you haven't done something moronic like put 440cc/min injectors in there.
[Updated on: Thu, 05 August 2004 09:39]
STR8 2.8
Re: 5MGE is teh ghey Thu, 05 August 2004 11:59 Go to previous messageGo to next message
i think they are rx7 injectors, my bro said they would make more power but i dunno.
Henn
Rosanna, Melb
Re: 5MGE is teh ghey Thu, 05 August 2004 12:09 Go to previous messageGo to next message
If you're running stock management and bigger injectors then you are in trouble. That would be why it's overfuelling.
The computer commands a certain amount of fuel to be injected, but the bigger injectors pump in more. Therefore you're running rich.
Go back to stock everything.
Hen
PS, what your bro should have said is that those injectors COULD SUPPORT more power. Big injectors alone won't make any power difference.
[Updated on: Thu, 05 August 2004 12:12]
STR8 2.8
Re: 5MGE is teh ghey Thu, 05 August 2004 13:31 Go to previous messageGo to next message
Laughing
I was just teasing mate.
Its running stock injectors.
It never ran properly (i dont know when i said it did), water temp and csi are wired up properly, its using the factory loom i havent exactly "wired" anything up.
Still runs rich without csi connected.
perhaps the regulator has shat itself?
Re: 5MGE is teh ghey Thu, 05 August 2004 22:55 Go to previous messageGo to next message
Put a pressure gauge on the fuel rail, that will tell you if the regulator is working properly or if you have other fuel pressure problems.
Also make sure the ECU is earthed really really well; this can cause all manner of strange problems! When my 18R-GEU ECU wasn't earthed properly the injectors would stop pulsing and stay 100% open, which obviously made the engine run incredibly rich and stall.
BlackSupra
Re: 5MGE is teh ghey Fri, 06 August 2004 10:05 Go to previous messageGo to next message
Norbie wrote on Fri, 06 August 2004 08:55
How the hell did you come to that conclusion and fix it?
Re: 5MGE is teh ghey Fri, 06 August 2004 13:27 Go to previous messageGo to next message
STR8 2.8 wrote on Thu, 05 August 2004 23:31
I'm pretty sure you said it ran just fine (before you rewired the old Microtech) in the seller's car.
Norbie's suggestion of earthing everything is good. Checking the fuel pressure is reasonable too. Maybe check the water temp sensor?
My money is still on something not wired up correctly.
Henn
Rosanna, Melb
Re: 5MGE is teh ghey Fri, 06 August 2004 17:03 Go to previous messageGo to next message
Sorry, didn't notice the note of sarcasm.
That exhausts all my suggestions... apart from doing a 1jz conversion.
Good luck
Hen
Re: 5MGE is teh ghey Sat, 07 August 2004 01:16 Go to previous messageGo to next message
BlackSupra wrote on Fri, 06 August 2004 20:05
I knew the injectors were opening because the car reeked of fuel as soon as you switched the ignition on, so I knew there was a wiring problem somewhere. Much probing with multimeters eventually led me to the conclusion that there was too much resistance between the ECU body and the chassis; I clamped a jumper lead to the ECU, and the other end to the engine block, and hey presto it started! Laughing
STR8 2.8
Re: 5MGE is teh ghey Sat, 07 August 2004 05:02 Go to previous messageGo to next message
gt:
Rolling Eyes well actually... it did run before we pulled it out fo the car. Laughing
but i just dont know where an electrical problem could exist...
ill go over the loom and check for shorts etc.
ive tried to make a better earth for hte computer so ill see how that pans out soon.
i was thinkin more along fuel delivery because it did all of a sudden start running uber rich with the old microtech, so i thought something may have shat itself.
thanks for the input fellas Very Happy
[Updated on: Sat, 07 August 2004 05:02]
jhalmers
Gunnedah NSW
What about 5me Thu, 26 August 2004 05:18 Go to previous messageGo to next message
sorry for changing the subject of this topic but i was wondering seem you know so much about toyota engines. Would it be possible to take an 84 cressida 5me engine and place it into a 84 corona st141
Re: What about 5me Thu, 26 August 2004 05:45 Go to previous messageGo to next message
jhalmers wrote on Thu, 26 August 2004 13:18
If you like customisation, and a car with a lead tip and no handling.
Basically, it will phyiscally fit (I tihnk), but will ruin all handling.
And besides, the 5me is a motor NOT worthy of converting too.
Get a 3sge, or 3sgte.
[Updated on: Thu, 26 August 2004 07:19]
STR8 2.8
Re: What about 5me Thu, 26 August 2004 05:59 Go to previous messageGo to next message
i second that...
5ME is teh UBER ghey!
Laughing
side note:
engine now runs beautifully Very Happy thanks to all who helped
Re: What about 5me Thu, 26 August 2004 06:03 Go to previous messageGo to next message
STR8 2.8 wrote on Thu, 26 August 2004 13:59
i second that...
Laughing
side note:
So, what did u do?
Fit all stock stuff and pulleys?
Re: What about 5me Thu, 26 August 2004 07:14 Go to previous messageGo to next message
jhalmers wrote on Thu, 26 August 2004 15:18
Hey, this is the third time you've asked the same question... ask it once and wait for a reply, don't pollute our forums with repeated questions!
Re: What about 5me Thu, 26 August 2004 07:20 Go to previous messageGo to next message
Norbie wrote on Thu, 26 August 2004 15:14
Can I pollute it with repeated answers?
YelloRolla
On your mum!
Re: What about 5me Thu, 26 August 2004 07:32 Go to previous messageGo to next message
STR8 2.8 wrote on Thu, 26 August 2004 15:59
i second that...
Laughing
side note:
What was it?
Was it a blocked return line?
STR8 2.8
Re: What about 5me Thu, 26 August 2004 07:59 Go to previous messageGo to next message
not too sure,
replaced some gaskets, and swapped the microtech back in, then the 5me loom back in and took it for a thrash and it cleared up. no trace of smoke now...
i dun get it Confused Confused
but its all good now so yeh!
Evil_Foetus
Ballarat, Victoria
Re: 5MGE is teh ghey Thu, 26 August 2004 08:54 Go to previous messageGo to next message
so its running?! whats it like?! Surprised
BlackSupra
Re: 5MGE is teh ghey Thu, 26 August 2004 09:16 Go to previous messageGo to next message
slow Wink
Evil_Foetus
Ballarat, Victoria
Re: 5MGE is teh ghey Thu, 26 August 2004 09:20 Go to previous messageGo to next message
hah! my 7mge will be the bomb Evil or Very Mad
if i can get it from adeliade Laughing
STR8 2.8
Re: 5MGE is teh ghey Thu, 26 August 2004 10:26 Go to previous message
Evil_Foetus wrote on Thu, 26 August 2004 18:54
eat me glen Twisted Evil
it goes much better than the 5me, lets just say that...
Previous Topic:RN41 hilux engine conversion
Next Topic:1G-FE Wiring Diagram
Current Time: Mon Nov 2 19:04:02 UTC 2026
Total time taken to generate the page: 0.1070020198822 seconds
