Toymods » General Car Talk » Panel Damage pass RWC?
Razor
Panel Damage pass RWC? Thu, 05 August 2004 23:41 Go to next message
my car's got front fender dented like squashed in (near headlight), no holes or anything not that bad nothins coming off or anything. Roof's got hail damage dents rear left door is scratched (bare metal can bee seen as paint came off) and dented
Will this pass QLD RWC?
How about ignition barrel? I got one but you can use any key as the previous owner change the ignition barrel with something weird its just got that like a "T" hole on it, so a flat screw can just start the car or any key. Or do I have to change this with proper one?
SIMDOG
Bayside Melbourne.
Re: Panel Damage pass RWC? Fri, 06 August 2004 03:53 Go to previous messageGo to next message
I think your only problem would be the bare metal on the panels... RWC testers are tight arses when it comes to rust, so if theres anything that looks remotely like rust or something that may promote it then you may not pass.
They are more likely to pass a car that looks like it has been cared for than something that looks like a piece of shit.
fade-e
Re: Panel Damage pass RWC? Fri, 06 August 2004 04:47 Go to previous messageGo to next message
if it was registered when you got it then yeah i recon only bare metal would be an issue, also with front damage as long as there is nothing sharp/protruding that could cause harm then thats fine.
-NiCkeL-
Melbourne, Victoria
Re: Panel Damage pass RWC? Sat, 07 August 2004 08:24 Go to previous messageGo to next message
Put some paint on the bare metal bits, that should sort that out.
The igniton barrel wouldn't pass, that's pretty dodgy...they'll have a reason for it not passing, like that if you can take the key out while the car is still running, it might fall out and you won't be able to turn it off. Rectify that, and you should be right.
SillyCar88
Elwood, Melb
Re: Panel Damage pass RWC? Sat, 07 August 2004 10:10 Go to previous messageGo to next message
Chassis gotta be straight too
Jag7799
Re: Panel Damage pass RWC? Sat, 07 August 2004 12:25 Go to previous messageGo to next message
yhah.. but how oftern will they test another key? lol
-NiCkeL-
Melbourne, Victoria
Re: Panel Damage pass RWC? Sun, 08 August 2004 07:33 Go to previous message
If the thing has been butchered, I doubt it'll pass!
Previous Topic:easiest way of taking a tyre off the rim
Next Topic: jza70 aftermarket bodykit
Current Time: Mon Nov 2 00:40:14 UTC 2026
Total time taken to generate the page: 0.006181001663208 seconds
