Toymods » Tech & Conversions » which EFI engines have TPS that isn't a switch?
which EFI engines have TPS that isn't a switch? Fri, 06 August 2004 03:29 Go to next message
hi folks,
can you help me compile a list of EFI engines in which the TPS is a variable potentiometer, not just an idle and WOT switch?
i've got something sorted for the 18R (a rb30 throttle body & tps) but if/when i do the 5me i'd like to find a toyota TPS so i don't have to adapt a mis-fitting sensor from another maker (and so far, all i can find and easily remove are v6 comodes, efi camira's and the occaisional nissan).
engine model & year v.useful (part # would be even better)
tia, charles.
[Updated on: Fri, 06 August 2004 03:30]
STR8 2.8
Re: which EFI engines have TPS that isn't a switch? Fri, 06 August 2004 04:05 Go to previous messageGo to next message
why cant you use the 5me one?
later model 5mge's had potentiometer tps's
but you'd have to find an import or import one.
Re: which EFI engines have TPS that isn't a switch? Fri, 06 August 2004 04:21 Go to previous messageGo to next message
5ME has switch(es) only
as does 18rgue (or so i've found so far)
am trying to avoid import cars as the wreckers keep closer eye on them
gearb0x
Re: which EFI engines have TPS that isn't a switch? Fri, 06 August 2004 04:36 Go to previous messageGo to next message
some bloke on the MS forum used one off an EA falcon on his 2tg
mounted it too the TPS backing plate on the TB
the tps backing plate is the same for the 18rg as far as i know
Edit: and as i check the tread again msot of that info is irrelevant Razz i guess add to the list EA tps's Smile
[Updated on: Fri, 06 August 2004 04:37]
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: which EFI engines have TPS that isn't a switch? Fri, 06 August 2004 04:40 Go to previous messageGo to next message
All 4ages for a start. Then I imagine all the later model engines, JZs, UZs, 3Ss, even 1Gs & 7Ms.
Re: which EFI engines have TPS that isn't a switch? Fri, 06 August 2004 05:58 Go to previous messageGo to next message
Ill be keeping an eye out at the wreckers tomorrow too. I'm doing an 18R-G, and i want to be using an aftermarket ECU - hence analog TPS.
Jayem
Finland
Re: which EFI engines have TPS that isn't a switch? Fri, 06 August 2004 18:17 Go to previous messageGo to next message
I have Weber TPS from efi Fiat. Direct replacement for bosch one.
people100
Rocklea qld
Re: which EFI engines have TPS that isn't a switch? Sat, 07 August 2004 10:06 Go to previous message
i got mine today off of a vl commodore 6 cylinder. mades some new mounts for it and it also takes the same plug as my old wiring. Only thing is the extra plug it has but im guessing we can just disregard it.
Previous Topic:1JZ into VL Commodore Conversion
Next Topic:Diagnosing a dead alternator (MA61 / 5mge)
Current Time: Fri Nov 20 04:55:58 UTC 2026
Total time taken to generate the page: 0.0053009986877441 seconds
