Toymods » Tech & Conversions » Blinkers stopped working
ta2272
Blinkers stopped working Fri, 06 August 2004 04:29 Go to next message
last night my blinkers were not coming on at all, this morning i got one corner out of them, a few months ago the same was happenining but they came good, anyone know what is going on.
Jason
fade-e
Re: Blinkers stopped working Fri, 06 August 2004 05:53 Go to previous messageGo to next message
1 of 2 things:-
1) blnker relay stuffed (its behind the fuse box next to your accelerator)
2) blinkers are not earthing but usually that makes the blinker turn on but doesnt flash (just stays on)
ta2272
Re: Blinkers stopped working Fri, 06 August 2004 06:07 Go to previous messageGo to next message
I have had them come on bfore and just stay on, this was happening when my alternator wasnt charging thought and my bat was really low, just running the car
Fattony
Re: Blinkers stopped working Fri, 06 August 2004 07:43 Go to previous messageGo to next message
Get yourself another relay, aint to difficult to change, i would say that it is most prob that being the cause, or one of your indicators isnt working, modern cars click really fast when a bulb is out, but i know my 23 just holds the light on.
ta2272
Re: Blinkers stopped working Sun, 08 August 2004 09:39 Go to previous messageGo to next message
but if the relay is gone doesnt isnt that the thing making them work, (my hazards still work fine)
Jason
fade-e
Re: Blinkers stopped working Sun, 08 August 2004 10:17 Go to previous messageGo to next message
Laughing not laughing at you mate but i had the same problem.
your hazards work on a different system completely than your blinker system. the hazards are for emergencies and therefore have their own relay which is directly connected to battery. hence why hazards work when car off!!! the hazards have the blinkers all connected together and then earthed at the relay and thats why it doesnt use the nuts on the blinkers for earthing
if it is the relay, then most electricians will tell you to go electronic as is cheap replacement and readily available and easy to install or you can source out another stock one.
just keep in mind that IF THEY COME ON AND STAY ON THEN IT IS EARTHING!!!!!!!!!!!!!!!!!!!!!!!!!!!
ta2272
Re: Blinkers stopped working Sun, 08 August 2004 10:48 Go to previous messageGo to next message
yeh ill buy one tomorrow is there just one of them for all four blinkers.
fade-e
Re: Blinkers stopped working Sun, 08 August 2004 10:56 Go to previous messageGo to next message
yeah just the one relay
ta2272
Re: Blinkers stopped working Mon, 09 August 2004 13:39 Go to previous messageGo to next message
Just to add some more discusion,
I was on my way to get the relay and my blinkers started working again, do we still think its the realay or could it be a faulty earth.
thanks alot.
Jason
MU553R
Re: Blinkers stopped working Mon, 09 August 2004 14:53 Go to previous message
yeh da relay, and clean the blinker swithces, get all da dust out and spray wd40 on the contacs.
and this has nothing to do with da blinkers... , dat can be very handy is to put relays on the headlights, and the starter motor.. jus make it easier for you to isolate problems if any of those things stuff up in the future.
Previous Topic:Please help me avoid cooking my SC12
Next Topic:Gearbox problem
Current Time: Wed Nov 18 11:08:14 UTC 2026
Total time taken to generate the page: 0.0050458908081055 seconds
