Toymods » Tech & Conversions » Speed sensor, what does it do?
BlackSupra
Speed sensor, what does it do? Sat, 07 August 2004 02:27 Go to next message
What is the job of the speed sensor?
Is it there purely to control the speed cut, or does it have another purpose?
Mine hasn't been plugged into anything since the conversion and i was just wondering if anyone could tell me what will happen if i a) remove it b) find a place to plug it in.
Here is a wiring diagram for it, the pink wire runs back to the ECU speed sensor pin.
http://www.mkiv.com/manual/1995_electrical_manual/ I/95elec_088.JPG
http://www.mkiv.com/manual/1995_electrical_manual/ I/95elec_089.JPG
wagonist
Toymods Club Treasurer
Re: Speed sensor, what does it do? Sat, 07 August 2004 08:14 Go to previous messageGo to next message
On later model cars, there is no speedo cable.
Instead, an electrical signal is generated off the sensor, then sent to the ECU for some reasons, like speed cut (speed =180km/h), idle (speed = 0), also a signal is sent to the instrument cluster to drive the speedo.
Most cars have this sensor on the gearbox where the speedo cable used to be, mine is driven off the front wheels ABS sensors.
Re: Speed sensor, what does it do? Sat, 07 August 2004 11:46 Go to previous messageGo to next message
Some ECU's use it for functions other than speed cut (e.g. idle control, A/T control), and sometimes others - some engines run a lot better with it connected.
Re: Speed sensor, what does it do? Sat, 07 August 2004 13:31 Go to previous messageGo to next message
Yep, my engine runs better with the sensor connected, but it's still ok without. It's also used for stuff like the cruise control.
BlackSupra
Re: Speed sensor, what does it do? Sat, 07 August 2004 14:24 Go to previous messageGo to next message
Well from what i can tell, this speed sensor is used to feed the trip computer, the speedo, ABS and the ecu.
The 2jzge came from a manual jza80 so it rules out all the AT stuff.
This could only possibly connect to the gearbox somehow in a similar fashion to the current cable gear i assume to work properly?
Re: Speed sensor, what does it do? Sun, 08 August 2004 01:22 Go to previous message
your dash has the 4 pulse per revolution output already on it glen. Its the output labelled "4P"
Previous Topic:AE86 suspension and steering suggestios.
Next Topic:1G-Gte in RA28
Current Time: Fri Nov 20 02:58:08 UTC 2026
Total time taken to generate the page: 0.0065011978149414 seconds
