Toymods » Tech & Conversions » AE86 brake upgrade
white86
AE86 brake upgrade Sat, 07 August 2004 04:45 Go to next message
Hi, i have an aus spec ae86 with the front disks/rear drums. I'm upgrading to a jap rear end (lsd, disks), but i was wondering if there are any common front brake swaps (e.g. graft the bottom half of some other strut on), maybe from a celica or something similar? I know of the the jap drilled or slotted rotors or whatever, but i'd really prefer something with a bigger diameter.
Also, does any one hav any prefered brake pads for street use? I've been recommended image c2 pads, but i'd like to see what peoples experiences are...
Thanks in advance.
doityourself
Hackham South Australia
Re: AE86 brake upgrade Sat, 07 August 2004 06:08 Go to previous messageGo to next message
Just a quikkie for you. I measured up RA60 struts, lower control arms and tie rods, and guess what they are the same as the KE20 corolla all except the spring diameter. Easily fixed though, simply cut off the spring holder off the AE86 and put them on the RA60 strut. You will need a 14" rim or larger. You should be able to get every thing you need from a wrecker for say.... $200 or $300. besides spring cups everything bolts on. i would recommend using the lower control arm from the RA60 as well.
Hope that helps you out.
LONG LIVE THE AE-86
Flogbag
Sydney (Campbelltown...!)
Re: AE86 brake upgrade Sat, 07 August 2004 06:32 Go to previous messageGo to next message
there is a article on this in the articles section and they use cressida struts disks and calipers with celica steering arms or something like that
Super Jamie
On Probation
North East NSW
Re: AE86 brake upgrade Sat, 07 August 2004 07:13 Go to previous messageGo to next message
hey doityourself, was the control arm bush the same between the ke20 and ra60? or do you need to get a custom bush lathed up?
i was thinking about putting scorpion control arms (to get 14mm balljoint thread), aus ae86 struts and brakes, and ae86 power steer arms in my ke25. should be able to get some lowered springs, and plenty of decent dampers around
Re: AE86 brake upgrade Sat, 07 August 2004 11:48 Go to previous messageGo to next message
Just a hint - RA60 struts will give you some pretty harsh positive camber...
Do a search, this topic has been covered to death
Super Jamie
On Probation
North East NSW
Re: AE86 brake upgrade Sat, 07 August 2004 12:46 Go to previous messageGo to next message
nah cbf, will just stick with the scorpion/ae86 idea if i ever do it, already got the measurements and shit i need
got adjustable tops to go in the 25 when i can be bothered, they'll have to do for now
doityourself
Re: AE86 brake upgrade Mon, 09 August 2004 13:21 Go to previous messageGo to next message
The measurements that i made were to fit on the KE 20, I only ment this as a suggestion that could be researched more, if one desired. Generally i have found that toyota have made alot of interchangable parts between models. Besides a back yard job the only other thing i can suggest is to go to someone like RPM or the likes but expect big bickies $$$ from $1500 up. Sorry i cant be anymore help.
ae86drift
sydney.au
Re: AE86 brake upgrade Mon, 09 August 2004 13:24 Go to previous messageGo to next message
buy the adapter plates from japan and get some FC rx7 brakes!
:D:D:D
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: AE86 brake upgrade Mon, 09 August 2004 13:52 Go to previous messageGo to next message
or get S13 LCA's, hubs and Sr20 brakes. plenty overkill and u can get some mean susp too.
Super Jamie
On Probation
North East NSW
Re: AE86 brake upgrade Mon, 09 August 2004 22:11 Go to previous messageGo to next message
who'd want to run datsun bits in their car tho Wink eeeewww
3sglevin
Re: AE86 brake upgrade Tue, 10 August 2004 03:51 Go to previous messageGo to next message
I Have RX7 4 spot calipers and rotors on my car and they fit under 14 inch wheels this is a good conversion.
psychofox
Wollongong, NSW
Re: AE86 brake upgrade Tue, 10 August 2004 04:00 Go to previous messageGo to next message
Garth,
What do the adaptors for the FC calipers cost? Are they reasonable?
Henn
Rosanna, Melb
Re: AE86 brake upgrade Tue, 10 August 2004 06:17 Go to previous message
Also done the FC brake conversion. Bloody great, never been able to get them to fade (EBC green pads and slotted rotors), despite trying really hard sometimes.
I can't give a direct comparison with any other options. But alloy calipers are lighter than the hilux 4pots. And keeping stock struts is a nice point too.
Probably overkill really unless you are track racing.
Hen
Previous Topic:Not another LSD question.
Next Topic:BRAKES TO FIT ON MY ST185 GT4
Current Time: Wed Nov 18 11:08:40 UTC 2026
Total time taken to generate the page: 0.0063998699188232 seconds
