Toymods » Tech & Conversions » Wolf3D Ver 4 Settings
celicaboy_2000
Lismore, NSW
Wolf3D Ver 4 Settings Sun, 08 August 2004 08:04 Go to next message
Everyone who's using a Wolf3D Ver4 I need a couple of settings:
*What is you Post start enrich rate (Found under START on the hand controller)?
*Engine temperature compensation rate (Found under FUEL on the hand controller)?
Thankyou
Matthew
IRA11Y
Club Member
Re: Wolf3D Ver 4 Settings Sun, 08 August 2004 10:12 Go to previous messageGo to next message
these setting will completely depend on your engine, but ill look at mine tomorrow and post it up
celicaboy_2000
Lismore, NSW
Re: Wolf3D Ver 4 Settings Sun, 08 August 2004 10:22 Go to previous messageGo to next message
Thanks, just want to compare mine to everyone else's. Trying to get mine sorted out so you never know your setting might be closer then the setting I have now. I think my setting are:
Post start enrich: 35
Engine temp comp: 50
[Updated on: Sun, 08 August 2004 10:24]
IRA11Y
Club Member
Re: Wolf3D Ver 4 Settings Mon, 09 August 2004 07:17 Go to previous messageGo to next message
Post Start enrichment is 75% Decay Linear @ 1%
Engine temp Comp. is 14%
celicaboy_2000
Lismore, NSW
Re: Wolf3D Ver 4 Settings Mon, 09 August 2004 08:10 Go to previous messageGo to next message
IRA11Y, What motor is this for? Also did you set up the engine temp comp using the PC software or just through the hand controller? The reason I ask is that you can modify the compensation rate at all the different temps. Thanks dude
Anyone else using the Wolf3D Ver4 or Ver3?
IRA11Y
Club Member
Re: Wolf3D Ver 4 Settings Mon, 09 August 2004 11:00 Go to previous messageGo to next message
its for a 4age, they were all set via laptop on the dyno, the rate i gave is for pre start, i.e when you provide power to the ecu before cranking. are you asking for the scale? because the scale adjusts the overall values but the comp rate is an individual setting that is applied to the ms rate at each step regarless, i.e if your at 2.0ms and the comp adds 1.0ms at Xtemp then you get 3.0ms and if your at a higher ms rate it still applies the same dose untill the cut off rpm ... then the rest is to do with the decay rate and weither is set at linear or the other settings.
celicaboy_2000
Lismore, NSW
Re: Wolf3D Ver 4 Settings Tue, 10 August 2004 08:18 Go to previous messageGo to next message
Hey, What you gave me is what I wanted (pre start fuel mixtures). So your car starts and run fine when cold? Ill try these settings on the weekend when I get my new water pump on and see how I go. Once agian thanks.
IRA11Y
Club Member
Re: Wolf3D Ver 4 Settings Tue, 10 August 2004 10:45 Go to previous message
well it depends on the air temp.. below about 12C its still quite difficult to start, needs about 3/4 throttle to make it fire but im running cams too and part of the problem on start up is air velocity. however around 14C or higher i can crank and it will fire and run roughly by itself untill it gets warm then its fine .. but you have to remember that my engine is no standard item so will never really run smooth until its warm anyway.
Previous Topic:wiring diagram
Next Topic:TA22 side indicators
Current Time: Wed Nov 18 17:02:42 UTC 2026
Total time taken to generate the page: 0.0053269863128662 seconds
