Toymods » General Car Talk » Need Springs compressed
ShiRi
Need Springs compressed Sun, 08 August 2004 10:34 Go to next message
Just fitted the springs and they aren't anywhere as low as i hoped... Should i buy new springs or just get these ones compressed? i was hoping for another 2" down...
where to go? how much am i looking at? cheers guys
improvedae86
Re: Need Springs compressed Sun, 08 August 2004 11:21 Go to previous messageGo to next message
Have you waited till the spring settles to its intended ride height ? This could take a few weeks depending on how much you drive . And its called spring reseting , which isn't advisable .
ShiRi
Re: Need Springs compressed Sun, 08 August 2004 11:23 Go to previous messageGo to next message
Had them in a week now and they still look the same
wait a bit longer?? get an allignment? will these things lower it?
its sitting so high atm Sad
improvedae86
Re: Need Springs compressed Mon, 09 August 2004 00:23 Go to previous messageGo to next message
No a alignment will not do anything to the height .
i could be the springs are fitted incorrectly Laughing
Take them back to the fitter for a full refund at once Sad
No really are you talking front of rear ? If they are kings springs then it should take them three or four attempts to get the height correct Crying or Very Sad . Unless you gave them all the correct information on heights , lengths , coil diameter etc .
ShiRi
Re: Need Springs compressed Mon, 09 August 2004 02:28 Go to previous messageGo to next message
fitted the suspension myself with help from takai and grant and gearb0x on these forums...
this is how it sits at the moment
http://image-cache.boostcruising.com/database/readersrides/files/ShiRi200408081745ridefile2.jpg
i was hoping for another 1-2" down... atm its just sitting to far from the wheel
Rallystanza
Re: Need Springs compressed Mon, 09 August 2004 02:54 Go to previous messageGo to next message
silly question maybe.... but did ya make sure ya ordered the low king springs and not just standard height with a greater spring rate. I have tried to suss out through king springs what the go is with lowered springs for the sprinter and they say there is only one height lower and its only by 30 or 35mm?
Jeremy
[Updated on: Mon, 09 August 2004 02:54]
ShiRi
Re: Need Springs compressed Mon, 09 August 2004 02:58 Go to previous messageGo to next message
yeh the kings are only 1" down.... thats the only set they made for them to my knowledge
improvedae86
Re: Need Springs compressed Mon, 09 August 2004 03:03 Go to previous messageGo to next message
Looks like normal height , Double check there part numbers on the springs , but knowing kings they could be numbered the lower model and not be . What where the guard to ground measurements before the change ?{taking note of wheels fitted} Four people to fit springs , Are you sure you needed one per corner ? Laughing Just add the four people into the car that will make it lower .
ShiRi
Re: Need Springs compressed Mon, 09 August 2004 03:06 Go to previous messageGo to next message
bought them off truenolevin on these forums new... so i'll ask him i guess...
you know of any other brands that make lower springs and i can get them in for less than $250?
didn't measure the guards since the fitting, but it seems lower to me...
[Updated on: Mon, 09 August 2004 03:07]
Hirogen
Melbourne, Australia
      WTF is a jabber?
Re: Need Springs compressed Mon, 09 August 2004 03:10 Go to previous messageGo to next message
improvedae86 wrote on Mon, 09 August 2004 13:03
lol, I think he has something there
shoot
Re: Need Springs compressed Mon, 09 August 2004 03:43 Go to previous messageGo to next message
ShiRi wrote on Mon, 09 August 2004 13:06
pm me might be able to
help
ae82rollaboy
Re: Need Springs compressed Mon, 09 August 2004 03:51 Go to previous messageGo to next message
i'm running king-springs superlows and they're sweet. could be a little lower at the front (the top of the rear wheel hides in the wheel arch very nicely!) but i think that they dropped it by about 2-2.5 inches. with stocky rims the car sits 10.5 cm off the ground. with 17"s its a bit higher, but still looks ok.
not sure if kingsprings make superlows for the ae86 (i dont see a reason why they wouldnt..) but superlows are the way to go. lows really make shit-all difference
http://us.f2.yahoofs.com/users/25df19a5_m40af576f/bc/3d71/__sr_/d405.jpg?ph0hvFBBiltFBreo
========cheers, roman=====================================
Henn
Rosanna, Melb
Re: Need Springs compressed Mon, 09 August 2004 04:33 Go to previous message
I run King lows. Look a little lower than yours, but may be due to different wheels/tyres.
Rallystanza is on the money. King (or Formula or whatever they actually are) only do stock height and 40mm down.
I got mine from Burson's in Heidelberg (Doherty rd). Can't remember price, but prolly be around 300 for the set.
You can have a look at mine when I come to pick up those wheels.
Hen
Previous Topic:Engineering costs and others
Next Topic:power steering pro's/con's
Current Time: Fri Oct 23 23:58:16 UTC 2026
Total time taken to generate the page: 0.0061688423156738 seconds
