Toymods » Tech & Conversions » 2t-g cam timing marks
skillygrant
cairns
icon5.gif  2t-g cam timing marks Mon, 16 September 2002 04:01 Go to next message
Hi I am in the process of rebuilding a 2tg engine to go in my old suzuki lj80 4wd.
I don't have a w'shop manual and was wondering if anyone could help me out with the info on cam timming setup.
any other info would be great to
James Very Happy
CelicaRA45
nth ringwood, Victoria
Re: 2t-g cam timing marks Mon, 16 September 2002 06:35 Go to previous messageGo to next message
set eng to TDC, start on exhaust side with no 1 cyl lobe facing exhaust manifold there will be a notch in the cam it has to be vertical keep chain as tight as possible till the pin fits then when it is done move onto inlet in the same way then screw in top tensioner very loosly till it bottoms in to the head then rotate 360 degress and check again
hemi twofifteen turbo
Re: 2t-g cam timing marks Tue, 26 July 2005 13:27 Go to previous message
hey i did a search to dig this up, and would like to add an additional question:
So as for the lower timing chain, I can put that on any way I like and it wont mean shit as long as I set the top timing chain so that the two slits in the cams are vertical while at TDC? It seems logical but I just want to comfirm that is true before i put everything back together.
Thanks.
Previous Topic:Hiace Engine Remove/Instal
Next Topic:3sgte Coolant temps..?
Current Time: Tue Oct 6 15:00:59 UTC 2026
Total time taken to generate the page: 0.054237127304077 seconds
