Toymods » Tech & Conversions » Removing clutch cable from K40
z|gen
Removing clutch cable from K40 Mon, 09 August 2004 02:05 Go to next message
hey
just wondering how do i remove the clutch cable from a K40 g/box, from what i can see, it goes through a bracket bolted to the block, then through the bellhousing(?) and then through to the clutch lever.
so far i have tried putting the clutch to the floor, but that just tightens the cable, the engine is a 4K if that helps at all, is there some way i can do this myself, or will i need someone else to help. ?
cheers David
pro_ke
adelaide
Re: Removing clutch cable from K40 Mon, 09 August 2004 03:13 Go to previous messageGo to next message
once you have taken the little hook part off the clutch fork you should be able to just pull the cable out through the hole in the bellhousing
spray a lot of CRC in there if it wont come out
z|gen
Re: Removing clutch cable from K40 Mon, 09 August 2004 03:20 Go to previous messageGo to next message
thats the part which im stuck at, cause i cant get the lil hook part off the clutch fork, as there is to much tension or something, is there a screw or something which i loosen offor is it sorta like removing the accelerator cable from the carby etc ?
pro_ke
adelaide
Re: Removing clutch cable from K40 Mon, 09 August 2004 03:40 Go to previous messageGo to next message
follow the cable up to the firewall and there should be a retaining clip you can take off - you might need a mate to help you pull on the cable so you can get the clip off
then the cable should slack a bit and you should be able to get the little hook off the clutch fork
ChuckLandwehr
Re: Removing clutch cable from K40 Mon, 09 August 2004 07:34 Go to previous messageGo to next message
David, you can release the clutch cable from the gearbox throw out bearing lever, by removing the circlip at the firewall end of the cable. However IF you wish to remove the cable from the bellhousing, you will also have to release the top end of the cable from the clutch pedal inside the car. You also have to remove the circlip at the front of the bellhousing(where the cable goes through)then you pull the clutch cable rearward out of the bell housing. I did a clutch job on a KE Rolla last week. Hope this helps.
regards Chuck.
z|gen
Re: Removing clutch cable from K40 Mon, 09 August 2004 08:41 Go to previous message
sweet cheers..i think i know what i should be doing now and where to look.
will have a look tomorrow when its day time - stupid winter darkenss at 6pm Mad
thanks for all your help guys Smile
- David
Previous Topic:Fabricated sills for early celicas.
Next Topic:ST162:: Power Steering Rebuild HELP
Current Time: Thu Nov 19 00:31:34 UTC 2026
Total time taken to generate the page: 0.0077850818634033 seconds
