Toymods » Tech & Conversions » BRAKES TO FIT ON MY ST185 GT4
GT4ON20IN
icon4.gif  BRAKES TO FIT ON MY ST185 GT4 Mon, 09 August 2004 02:36 Go to next message
HI GUYS JUST WONDERING IF ANY1 WOULD KNOW OF ANY BIGGER BREAKS THAT FIT AN ST185 GT4 WHICH ARE OFF ANOTHER MAKE OR MODEL. ANY HELP WOULD BE GREAT
Classique71
Colac, Victoria
Re: BRAKES TO FIT ON MY ST185 GT4 Mon, 09 August 2004 02:46 Go to previous messageGo to next message
TAKE OFF CAPS LOCK!
the only ones you can look at as a direct or semi direct swap are 2 piston JDM brakes off their st185's or st205 4 spot calipers - which require some modification ..
the 4 spots are VERY HARD to come by and premium prices are asked for them
outside of that - custom fabrication is your only option
r33 skyline gtr brembo brakes have been used by a member of this forum with good results but it was a total custom fit
toof
Re: BRAKES TO FIT ON MY ST185 GT4 Mon, 09 August 2004 23:12 Go to previous messageGo to next message
the twin piston jdm ones are great. they also use the standard gt4 pad so getting pads isnt too hard.
they can be sourced fairly eaisly, ive bought 2 sets for the aw11's and work briliantly.
toof
Re: BRAKES TO FIT ON MY ST185 GT4 Mon, 09 August 2004 23:13 Go to previous messageGo to next message
Draza
Wahroonga
Re: BRAKES TO FIT ON MY ST185 GT4 Tue, 10 August 2004 05:53 Go to previous messageGo to next message
you might not need bigger brakes, try useing better pads and DBA golds.
toof
Re: BRAKES TO FIT ON MY ST185 GT4 Tue, 10 August 2004 05:59 Go to previous messageGo to next message
Draza wrote on Tue, 10 August 2004 15:53
and if thats not enough go for the twin piston numbers and they will use all your old gear (ie slotted rotors and better pads)
spectral
Re: BRAKES TO FIT ON MY ST185 GT4 Tue, 10 August 2004 06:10 Go to previous message
the ST185 JDM twin piston setup is actually smaller in diameter than the single piston setup.
There are no "bolt on" upgrades that are worth doing. All will have a custom component and will require engineering. Which is expensive for brakes.
I'm doing a 326x30 upgrade with R32 GTST 4-spot calipers. Completely new CNC aluminium brackets are being made up to fit them.
Previous Topic:AE86 brake upgrade
Next Topic:1JZ/2JZ Fuel rails?
Current Time: Wed Nov 18 11:29:14 UTC 2026
Total time taken to generate the page: 0.0045289993286133 seconds
