Toymods » Tech & Conversions » fuel pump on a 4M
Bradelz
Tamworth
fuel pump on a 4M Mon, 09 August 2004 10:02 Go to next message
hey guys,
my fuel pump was leaking fuel and when i started the car it got worse, i think its the original one - so i took it off and im going to get it replaced. so is it fucked if its leaking fuel? i always thought when they went they leaked oil.
cya dudes
Re: fuel pump on a 4M Mon, 09 August 2004 10:27 Go to previous messageGo to next message
Depends. Sometimes the rubber diapragms can tear from fatigue resulting in the pump not working. Pull it apart and have a sticky beak. A second hand one won't set you back more than $10-20 from the wreckers, or you could replace it with a low pressure electric fuel pump.
Bradelz
Tamworth
Re: fuel pump on a 4M Mon, 09 August 2004 10:32 Go to previous messageGo to next message
okay thanks gianttomatoe again! ummm how much does the low pressure eletric ones cost? does it make it go better?
brad
Re: fuel pump on a 4M Mon, 09 August 2004 13:49 Go to previous messageGo to next message
Brad,
not sure - ask at an auto parts store. An old secondhand Mazda pump from the wreckers might set you back $10-20.
No it won't make your car go any better. The carburettor, if it is doing its job right, will dispense only the fuel the engine needs. Delivering more fuel to the carburettor will only result in more of it to be returned to the fuel tank (provided the fuel pressure is not so high as to overcome the needle and seat).
Your easiest and cheapest option is to just get a good secondhand mechanical pump.
Johnny Blade
Sweden
Re: fuel pump on a 4M Mon, 09 August 2004 18:41 Go to previous message
Will a fuelpump(not electric)from any other enginefamily fit?
I have a 5M with a 2M fulepump (and head)and it's sucking very bad when the engine is hot(strange).
Previous Topic:AE101 4AGZE wiring??
Next Topic:RA28 parts into a TA22
Current Time: Wed Nov 18 20:11:00 UTC 2026
Total time taken to generate the page: 0.0057029724121094 seconds
