Toymods » Tech & Conversions » Roll cage and engineering NSW
the dayo
Roll cage and engineering NSW Tue, 10 August 2004 06:31 Go to next message
i'm planning to put a 20V into a KE20, and also add a roll cage, can this be engineered for road use in NSW? what have people come across, or someone i can talk to. i know i'll need bigger brakes etc. i just want to know about the cage
st184 sillycar
Re: Roll cage and engineering NSW Tue, 10 August 2004 06:45 Go to previous messageGo to next message
Pretty sure it's hunky-dorey for road-reg if it's been engineer-o.k'd and certified. There's heaps of Tarmac-Rally cars around that are Barred-out, and road-Reg'd/.
-I'm no authority though: ask your engineer / RTA
bob m
canberra
Re: Roll cage and engineering NSW Tue, 10 August 2004 07:35 Go to previous messageGo to next message
st184 sillycar wrote on Tue, 10 August 2004 16:45
Technically this is correct.
However, their registration may well be "rally registration". Rally registration generally limits them to competing in rallies, and driving to and from garages, etc for maintenance. Apart from these circumstances, they generally have to be trailered everywhere. You certainly can't use a car with rally registration for everyday commuting/weekend cruising.
kingmick
Banned by his request
moved to tamworth
Re: Roll cage and engineering NSW Wed, 11 August 2004 02:30 Go to previous messageGo to next message
most want do full weld in! they accept rear weld-in and front bolt. i only know of two that do full complex weld-in cages for full raod rego cars and they only do it for a few people that build race cars etc.
mick
Re: Roll cage and engineering NSW Wed, 11 August 2004 03:00 Go to previous messageGo to next message
the main problem will be headspace restrictions for the front section and the main hoop.
from the "code of practice of light vehicle modification"
(i apologise for the size)
http://www.materials.unsw.edu.au/~sford/COPLVM-rollcage4.jpg
as mick said, rear weld in (or bolt) with a bolt in front section for 'off-road' is acceptable.
to have a full cage with tubes near your head and A pillars would require some fancy bending and construction to maintain headspace...
45aken
NSW.south coast.Drifting
Re: Roll cage and engineering NSW Wed, 11 August 2004 14:21 Go to previous messageGo to next message
what about the legalness of a halfcage?
Re: Roll cage and engineering NSW Wed, 11 August 2004 14:26 Go to previous messageGo to next message
see above, as long as it satisfies the head room constraints, and it not a danger in any other way, it should be ok. but please talk to your favourite engineer first.
rear seats = no rear cage unless seats are removed etc.. main hoop can't get in the way of your head either...
Re: Roll cage and engineering NSW Thu, 12 August 2004 07:10 Go to previous messageGo to next message
If you were in Qld I know someone that can do you a fully welded in cage with side intrusion bar that is CAMS/ANDRA approved, and fully street legal.
st184 sillycar
Re: Roll cage and engineering NSW Fri, 13 August 2004 00:46 Go to previous messageGo to next message
oldcorollas wrote on Thu, 12 August 2004 00:26
Yeah, that reminds me: It's reasonably easy to get a halfcage certified, as long as it doesn't intrude on front headroom, and the rear seats AND seatbelts are removed. Pretty sure most engineers don't even wanna look at full-cages, but phone around to find out fer-shure.
Of course, a half-cage only helps in a roll-over, whereas a welded-in fully sik (sic) full-cage will work goddamn miracles for da little KE20's survivability in all crashes.
SICK MAYTE!!
fade-e
Re: Roll cage and engineering NSW Fri, 13 August 2004 01:17 Go to previous messageGo to next message
call me ignorant but wuld a half cage help in the cars stability at all or is it literally for rolls only???
Re: Roll cage and engineering NSW Fri, 13 August 2004 01:55 Go to previous messageGo to next message
st184 sillycar wrote on Fri, 13 August 2004 10:46
SICK MAYTE!!
KE20's don't survive crashes, althougha full cage might keep the bits together for longer Wink
ahh the price of small cars Sad
half cage mostly just roll only, unless it was well designed and tied into rear 'important' points.. even then wil only stiffen up the rear of the car.
st184 sillycar
Re: Roll cage and engineering NSW Fri, 13 August 2004 03:24 Go to previous messageGo to next message
oldcorollas wrote on Fri, 13 August 2004 11:55
SICK MAYTE!!
That's what I meant - a half-cage only stops the roof from caving in when you roll. It does nothing in a frontal, or most side-impacts. A PROPER integral cage would survive most crashes, regardless of how the car disintegrated around/inside it. May I suggest mounting the seat onto the (full) rollcage?
Mookie
Tassie
Re: Roll cage and engineering NSW Fri, 13 August 2004 09:22 Go to previous message
if u mounted it externally it would survive a few crashes. We got RV rego for a lada car we rallyied up . i dunno what would happen if we tryed for full rego. the main problem would be if we hit a person they might get messed up pretty bad .
Previous Topic:If you use a celicamad known as Hyperboost control read this
Next Topic:crown ms95 2 and 4 doors
Current Time: Fri Oct 23 15:15:44 UTC 2026
Total time taken to generate the page: 0.0052351951599121 seconds
