Toymods » Tech & Conversions » can st141 front brakes and struts fit into a sprinter
mrf_ool
Taree (4 hrs north of syd...
can st141 front brakes and struts fit into a sprinter Tue, 10 August 2004 07:53 Go to next message
been looking in the articles under brakes conversion they say they can fit with the steering arm but other articles say no but can get a whole car so if i have to change more stuuf its no problems eg lower arms and stuff but need to know a bit befor i get its cost me nothing for the car but just the time and energy to get it..
[Updated on: Tue, 10 August 2004 12:46]
Re: st141 front brakes into a sprinter Tue, 10 August 2004 08:06 Go to previous messageGo to next message
ST141 stub axles are bigger than the AE86 stub axles, so you can't swap the ST141 hubs/brakes onto your struts. You probably can swap the whole strut, but if you're going to all that effort you might as well swap in RA60 struts which have much better brakes.
mrf_ool
Re: st141 front brakes into a sprinter Tue, 10 August 2004 12:02 Go to previous messageGo to next message
yeah but cant get any around here and its free. bigger stubs is what i want r they the same as ra60 xt130 and them
[Updated on: Tue, 10 August 2004 12:48]
SEXY 16
ghetto area 2745
Re: st141 front brakes into a sprinter Tue, 10 August 2004 12:03 Go to previous messageGo to next message
any pictures??
AE86slut
Baulko Hillo
Re: st141 front brakes into a sprinter Tue, 10 August 2004 12:08 Go to previous messageGo to next message
SEXY 16 wrote on Tue, 10 August 2004 22:03
any pictures??
Laughing Laughing Laughing Laughing Laughing Laughing Laughing
mrf_ool
Re: st141 front brakes into a sprinter Tue, 10 August 2004 12:45 Go to previous messageGo to next message
just asking about it..
Re: can st141 front brakes and struts fit into a sprinter Tue, 10 August 2004 23:01 Go to previous messageGo to next message
Yes the ST141 stub axles are the same as the RA60.
mrf_ool
Re: can st141 front brakes and struts fit into a sprinter Wed, 11 August 2004 05:15 Go to previous messageGo to next message
thats great but can i put the struts in.. dont care if i have change stuff .. just need to know
mrf_ool
Re: can st141 front brakes and struts fit into a sprinter Wed, 11 August 2004 05:35 Go to previous messageGo to next message
o.k o.k if i go thr ra60/5 way do i need to change the steering arms..dont care about camber just need bigger brakes and going to use adjustable strut tops..
EVOSTi
cambo
      no
Re: can st141 front brakes and struts fit into a sprinter Wed, 11 August 2004 10:09 Go to previous messageGo to next message
if your talking about the hilux/pug upgrade, in regards to needing to change lower control arms i can assure you you DO NOT need to change lower control arms as i indicated in my article. the reason being some people use washers to space the caliper in its correct position whereas i machined the 'hat' of the disc to get it in its correct position. this is the better way and is perfectly safe as the hat of the disc is very thick.
mrf_ool
Re: can st141 front brakes and struts fit into a sprinter Wed, 05 January 2005 11:38 Go to previous messageGo to next message
so r they a bolt 1 piece or 2 piece hub and disc
rokusan
western queensland
Re: can st141 front brakes and struts fit into a sprinter Wed, 05 January 2005 12:08 Go to previous messageGo to next message
i have the entire uprights from an SA63, would you like some pic's or mesurements? they're for sale and....i've got RA40 lower control arms Surprised
wheres Taree? inland or is that Moree? i'm west qld
mrf_ool
Re: can st141 front brakes and struts fit into a sprinter Wed, 05 January 2005 12:40 Go to previous messageGo to next message
org86t has an weld on coil kit on his standard struts so i was trying to find an simple brake upgrade as he already has an st141 disc diff.
Sam_Q
S.E suberbs, Vic
Re: can st141 front brakes and struts fit into a sprinter Thu, 06 January 2005 11:43 Go to previous messageGo to next message
I thought that the angle at which the axel comes of the strut on a RA-60 strut was incompatible, and makes the car handle like crap even if you correct the camber?
I am using coil-overs based on a RA-28 strut myself.
foxtail
January 2005
Re: can st141 front brakes and struts fit into a sprinter Fri, 07 January 2005 01:25 Go to previous message
I have a AE86, AE85 and KE70 with RA60 struts and it handles fine. I have 2-3deg neg camber.
All up probably had 5 cars with RA60 struts and all were good
Previous Topic:Ta22 Brake upgrade!!
Next Topic:turbo info
Current Time: Sat Oct 17 07:07:22 UTC 2026
Total time taken to generate the page: 0.0049660205841064 seconds
