Toymods » Tech & Conversions » AE86 vacum hoses
$450 ta22
vic Castlemaine
AE86 vacum hoses Tue, 10 August 2004 10:09 Go to next message
Ive just put an 4age in my sprinter the cars running but i have a few hoses that i dont no where they go
firstly the two vacume hoses at the front of the manifold i dont no where they should go
Secondly the the little adjustable gadget on the drivers side strut tower has a hose going into it but the one comeing out has no where 2 go also it isnt pluged into the loom WHAT IS IT?
will the wires from the 4ac 1 do?
Any help Much appreciated
RobertoX
Re: AE86 vacum hoses Wed, 11 August 2004 00:12 Go to previous messageGo to next message
I think that little gadget is probably the aircon idle-up solenoid, did you keep the aircon? if not just block the connection on the manifold for it... If you did keep the aircon it should connect to the sprinter body loom not the engine loom, it then connects to the throttle body somehow and when the aircon is on it opens and raises the idle to compensate for the load placed by the compressor...
I just blocked all the vaccum connections on my inlet (the few that are on the TB anyway) and it runns fine...
Oh mine is a bluetop BTW
Hope this helps
FKN16V
NSW, East Coast
Re: AE86 vacum hoses Wed, 11 August 2004 06:39 Go to previous messageGo to next message
$450 ta22 wrote on Tue, 10 August 2004 20:09
RobertoX is right, and the 2 others you mention, which im thinking are on the front of the throttle body, 1 is for the charcol canister, and the other is for the air-co idle up, which should be blocked if your not using airco.
Steve
$450 ta22
vic Castlemaine
Re: AE86 vacum hoses Wed, 11 August 2004 13:10 Go to previous message
Thanks for the help
The cars also running incredibly rich and seems to miss a bit
i was hoping the hoses were the cause but not by the sounds
of it what may this be?
Once again all help its greatly appreciated
Previous Topic:URGENT HELP REQUIRED
Next Topic:3tgte clutch
Current Time: Mon Nov 2 06:28:01 UTC 2026
Total time taken to generate the page: 0.0049281120300293 seconds
