Toymods » Tech & Conversions » Fuel Pump Relay - 1G-GTE???
Darkstar
Ebbw Vale, Qld
Fuel Pump Relay - 1G-GTE??? Wed, 11 August 2004 01:00 Go to next message
Hi guys.
I have a 1G-GTE in a cressi and I noticed that when the engine was removed ( i didnt cut any wires on the engine loom) left behind was the fuel pump relay. The wires seem to have been cut although I didnt do it, and I cant find where the wires from the engine to the relay are.
Is that because the relay is part of the body electrics?? What should I do?? Please any advice from u 1G'ers would be great.
p.s sorry i don't have pictures, but i dont know how to attach them to this message Embarassed
Re: Fuel Pump Relay - 1G-GTE??? Wed, 11 August 2004 01:38 Go to previous messageGo to next message
might be worth your wile to go over a decent 1G wiring diagram
FP relay should be part of the engine loom - but is disconnectable as it tends to hide inside the car, not engine bay.
copy of one wiring diagram here:
<http://members.optushome.com.au/mkhala/red_celica/ 1G-GTE_info/>
and links at the bottom of that page goto some wiring diagrams and tech articles.
(PM me if the links are dead)
but there are plenty more about the place and this site - searching for "1G wiring" or "1G-GTE wiring" or "1GGTE wiring" will help.
Darkstar
Ebbw Vale, Qld
Re: Fuel Pump Relay - 1G-GTE??? Wed, 11 August 2004 02:01 Go to previous messageGo to next message
well it was definitely in the engine bay, and from the looks of the diagrams I have, it comes from the computer, But how come I can't find the cut wires Confused.
Maybe I'll have to look harder
Re: Fuel Pump Relay - 1G-GTE??? Wed, 11 August 2004 02:11 Go to previous messageGo to next message
the wrecked RA40+1G-GTE that i got my hardware from had the relay and current limiting resister ibehind the left kick panel - put there by the sparkie who did the transplant.
there is a round 4-pin plug AND a smaller 2-pin rectangular plug between the relay/resister unit and the engine/ECU loom - the ECU side of those plugs (in my loom) had a new power line put in direct to the battery - but i'd say a factory install has power coming from the large white cable that runs thru the body loom from the alternator/battery.
you could adapt something from a post-5m car (i think 6mge has current limiting in the the FP relay, 5m doesn't) so MX8x cresidda might be a useful donor. again, check passenger kick panel as well as engine bay.
the original source of my 1G-GTe was an MZ soarer
do you want a pic of the relay/resister pack? PM with email add to send to and wether small/large files are suitable.
Darkstar
Ebbw Vale, Qld
Re: Fuel Pump Relay - 1G-GTE??? Wed, 11 August 2004 10:57 Go to previous messageGo to next message
Well anybody else got any ideas??
sideshow
Re: Fuel Pump Relay - 1G-GTE??? Wed, 11 August 2004 11:49 Go to previous message
the fuelpump relay is the circuit openin relay
this i susually inside on the body harness
near the 3rd plug on the ecu
di du cut the 3rd plug off the body loom
if u didnt then its still in front cut
Previous Topic:Surge tank
Next Topic:auto ecu in manual
Current Time: Mon Oct 19 13:46:12 UTC 2026
Total time taken to generate the page: 0.025592088699341 seconds
