Toymods » Tech & Conversions » celica steering box compatability (pre 81') - (now has diagram for p/s conversion) check it out
brett_celicacoupe
townsville NQLD
celica steering box compatability (pre 81') - (now has diagram for p/s conversion) check it out Wed, 11 August 2004 03:19 Go to next message
hi,
i was wondering if any steering boxes from xA22 , xA23 and xA28 would be the same as an ra40. if so ive got news for every1. cressida power steering box will bolt straight in. well it does in my ra40.
-power steering for everyone
[Updated on: Wed, 11 August 2004 10:45]
Re: celica steering box compatability (pre 81') Wed, 11 August 2004 03:36 Go to previous messageGo to next message
brett, do you have pics of how you modified the steer column to adapt to the cresidda steer box?
i thought the box needed a new hole thru the chassis rail and the extra length of the shaft going into the box meant the stock shaft was too long.
you used the pitman arm from the ra40?
btw: am reasonably sure ra40/ra23 have same steering box - others will have to advise on the earlier TA's and the 28
ozboy
Re: celica steering box compatability (pre 81') Wed, 11 August 2004 03:50 Go to previous messageGo to next message
im interested in power steering for my 1973 TA22 if any one on this thread can help... sorry for the highjack i thought it was relevant
Thanx
brett_celicacoupe
townsville NQLD
Re: celica steering box compatability (pre 81') Wed, 11 August 2004 04:09 Go to previous messageGo to next message
hi all,
this is a old topic i wrote a while ago, it seemed nobody was interested in ra40 conversions. should explain most. ive completed this conversion and it works great, the only problem i had was the pump leaked - jus needs a new seal.
hi guys
i have found that many cressida parts will fit onto my ra40. firstly power steering, the bolt holes all line up perfectly, so no new holes will need to be drilled or modified. the only problem i encountered is that the 2 pin rubber disc plate that connects to the steerin column shaft sits about 15 - 20 mm to far up. this can be corected by sliding the 2 pin rubber disc plate down on the steering box spline as far as it will go, then tightening the bolt which holds it there. this only leaves it out by about 7mm. to get this extra 7mm the steering shaft will need to be machined at the the top end so the ignition switch and bearing can be slid back into its origional position. brackets for the pump will need to be fabricated.
power locking will literally bolt in, but conecting rods will need to be made to join the locking mechanism with the electromagnet.
power windows are a bit of a challange as the winder frames are different between cressidas and celicas. i cut both winder frames at the same position and the welded the bottom part (cressida - where electric motor bolts on) to the top part (celica winder frame)- this combination seems to work fine. 2 existing holes can be used but 2 new hole will need to be drilled. spacers need to be used on all holes because the electric motor sits out furthur than what the celica winder frame does.
many other parts are interchangable like, throttle cable, elec. ignition igniter assist, radiator, center console and much more
i hoped this article can help someone.
brett
CrAiGzEE
south of the big smoke
Re: celica steering box compatability (pre 81') Wed, 11 August 2004 06:32 Go to previous messageGo to next message
just stumbled across this, i am set to do it in the next few weeks will let ya know how i go
Re: celica steering box compatability (pre 81') Wed, 11 August 2004 08:04 Go to previous messageGo to next message
pics bro pics!!
send em this way and ill even make a little webpage to be added to my collection.
brett_celicacoupe
townsville NQLD
Re: celica steering box compatability (pre 81') Wed, 11 August 2004 10:22 Go to previous messageGo to next message
i drew a good diagram in autoCAD. it doesnt come out clear when i print screen it to paint as GIF. i will get real photos soon thou.
brett_celicacoupe
townsville NQLD
Re: celica steering box compatability (pre 81') Wed, 11 August 2004 10:38 Go to previous messageGo to next message
here is that diagram, its not very good quality but its readable
try 1 of these links
http://img63.exs.cx/img63/3249/RA40P-SDIAGRAM.jpg
http://img63.exs.cx/my.php?loc=img63&image=RA4 0P-SDIAGRAM.jpg
if any1 has any ques jus see me on messenger
Re: celica steering box compatability (pre 81') Wed, 11 August 2004 13:31 Go to previous messageGo to next message
so... if i:
- got the splines machined futher up the shaft
- cut the excess length off the shaft at the bottom
- repositioned the the plate
i could leave the top section alone?
i'd prefer to modify one end only.
btw: that diagram is great and has inspired me - i'll grab a MX6x P/S box next time i'm at wreckers and check this out further
crazedrt104
Darwin
Re: celica steering box compatability (pre 81') - (now has diagram for p/s conversion) check it out Wed, 11 August 2004 22:48 Go to previous messageGo to next message
any particular cressy model???
Re: celica steering box compatability (pre 81') - (now has diagram for p/s conversion) check it out Wed, 11 August 2004 23:08 Go to previous messageGo to next message
Can I just give the RA23/8 people a warning. I tried putting a RA40 box in my 28 and the bolt holes didn't line up.
2 were fine, but 1 was out by quite a bit.
Joel
CrAiGzEE
Re: celica steering box compatability (pre 81') Thu, 12 August 2004 00:25 Go to previous messageGo to next message
the steering colum is two piece it slides in side each other, its held together with locating pins, apparantly you can knock them out to allow for the 7mm then reposition it so machining is necessary
CrAiGzEE
Re: celica steering box compatability (pre 81') Thu, 12 August 2004 00:31 Go to previous messageGo to next message
mx32 and 62 are the boxs here is another link to a similar thread
http://forums.toymods.org.au/index.php?t=msg&t h=33069&rid=35&S=f2f5a9dff0c50f6e997638a55 0e4ba94&pl_view=&start=0#msg_290098
http://forums.toymods.org.au/index.php?t=msg&t h=13094&rid=35&S=f2f5a9dff0c50f6e997638a55 0e4ba94&pl_view=&start=0#msg_106067
chrishulbert
Castle Hill NSW
Re: celica steering box compatability (pre 81') Thu, 12 August 2004 00:36 Go to previous messageGo to next message
CrAiGzEE wrote on Thu, 12 August 2004 10:25
Are you saying that if we machine it, we can fit the corona box into an ra28?
CrAiGzEE
Re: celica steering box compatability (pre 81') Thu, 12 August 2004 01:15 Go to previous messageGo to next message
im talking about the colomn not the box, if the box doesnt line up u may have to redrill the mounts for the box, and also mess aroud with the correct steering arm below the box,
if you guys wait a couple weeks ill have done mine and ill write a well documented tech article for it
chrishulbert
Castle Hill NSW
Re: celica steering box compatability (pre 81') Thu, 12 August 2004 02:04 Go to previous messageGo to next message
CrAiGzEE
Sounds awesome!
You *do* own an ra28, don't you?
CrAiGzEE
Re: celica steering box compatability (pre 81') Thu, 12 August 2004 02:08 Go to previous messageGo to next message
23 but same thing
chrishulbert
Castle Hill NSW
Re: celica steering box compatability (pre 81') Thu, 12 August 2004 02:26 Go to previous messageGo to next message
Sen-frigging-sational. Well, make sure you let me know when you've done it, coz i'm not liking the wandering feeling of the balljoint steering much.
brett_celicacoupe
townsville NQLD
Re: celica steering box compatability (pre 81') - (now has diagram for p/s conversion) check it out Thu, 12 August 2004 03:51 Go to previous messageGo to next message
yeah um after i machined it i found that the column is 2 piece and has 2 locating pins. i havent done it but i reckon they could be knocked out and 2 new holes drilled, then the correct column length could be acheived. anyone that does it should let me know how it goes. doing it this way would let you not have to machine anything.
cressida model = 81-83 all the same
got mine from a 83 and for free
[Updated on: Thu, 12 August 2004 04:03]
7M-Brisbane
Re: celica steering box compatability (pre 81') - (now has diagram for p/s conversion) check it out Sun, 29 August 2004 13:07 Go to previous message
Well, I am deleting the power steering box from my MX13 Corona Mark II (precursor to MX32 Cressida) and converting to rack & pinion.
I have an RT104 Corona, and I've heard that these are very very similar to the RA40, but yet to be seen. I will certainly give it a bash, and will post here how I go!
Previous Topic:help!! 2a-c engine runs backwards after turning off
Next Topic:1ggte front pulley swap with...??
Current Time: Fri Oct 23 04:46:43 UTC 2026
Total time taken to generate the page: 0.11044406890869 seconds
