Toymods » Tech & Conversions » 7mgte diagnostics
nushi
7mgte diagnostics Wed, 11 August 2004 09:17 Go to next message
Have Turbo 7M GTE. When you bring it into boost it runs like shit. Blows black (fuel) smoke and won't perform. Any ideas out there and or links to find out. Thanks
cseufert
Melbourne Vic
Re: 7mgte diagnostics Wed, 11 August 2004 13:17 Go to previous messageGo to next message
You tried retrieving the codes from the ecu?
checked your spark plugs, leads, o2 sensor and timing?
1ndecent
Re: 7mgte diagnostics Wed, 11 August 2004 13:45 Go to previous messageGo to next message
Could be a boost leak. Loosing air that has passed through the airflow meter will make it run rich, giving the symptoms you described. Check for crack in intercooler hoses ans make sure your compressor bypass valve(blowoff valve) has not failed.
Re: 7mgte diagnostics Wed, 11 August 2004 23:41 Go to previous messageGo to next message
Yep, those are classic symptoms of a boost leak. They can be pretty hard to track down with the factory inlet piping, so check carefully.
nushi
Re: 7mgte diagnostics Sat, 14 August 2004 07:14 Go to previous message
Found the problem was boost leak. Bastard hose at turbo uytlet, Nice little job for us with big hands.
Previous Topic:aircon/fan/cig lighter not working
Next Topic:Carby setup for 4age 16v in ae86
Current Time: Sat Oct 24 03:58:07 UTC 2026
Total time taken to generate the page: 0.0051050186157227 seconds
