Toymods » Tech & Conversions » 3tgte clutch
rb20det
3tgte clutch Wed, 11 August 2004 09:58 Go to next message
is the clutch attached to the gearbox that comes with at 3tgte engine the same as the standard ta22 5speed clutch?? if not what is the gearbox that comes with the 3tgte and wat would be the part number for the clutch?
TE72_Turbo
Re: 3tgte clutch Wed, 11 August 2004 12:31 Go to previous message
3TGTE came out with a W55 gearbox as standard, so no, a TA22 5 speed clutch will not fit.
What gearbox do you have?
You 'could' bolt a TA22 flywheel, clutch & T50 gearbox to the 3TGTE, but its a bit small if you plan to push any power.
Sorry, dont have an actual part number for the 3TGTE clutch, but I can tell you that its a 9" diameter clutch face, with 29mm x 21 spline input shaft.
Phil
Previous Topic:AE86 vacum hoses
Next Topic:Surge tank
Current Time: Wed Oct 21 02:53:23 UTC 2026
Total time taken to generate the page: 0.0047810077667236 seconds
