Toymods » Tech & Conversions » Old abused W58
joorsh
Old abused W58 Wed, 11 August 2004 13:06 Go to next message
Well with my shifter out I figured it was time for a bit of an oil change. How much oil does the standard MA61 W58 gearbox take, and what oil would you guys recommend for a box that cops a bit of abuse and has synchro's on the way out?
And don't just say penrite shockproof. Smile
-J-
xl912
Re: Old abused W58 Wed, 11 August 2004 20:11 Go to previous messageGo to next message
Try a synthetic automatic transmission fluid.
2nd gear syncro was tired on mine and notchy to engage. Swapped to ATF and now it's sweet and smooth.
joorsh
Re: Old abused W58 Thu, 12 August 2004 00:06 Go to previous messageGo to next message
Yup, 1st to 2nd synchro is the worst on mine too. That's usually the one that cops it worst in post people's cars. Damn that traffic light grand prix Smile
How much oil did it take?
-J-
Re: Old abused W58 Thu, 12 August 2004 00:52 Go to previous messageGo to next message
Redline Lightweight Shock Proof
Spanktown
Inside a giant turbo (syd...
Re: Old abused W58 Thu, 12 August 2004 00:58 Go to previous messageGo to next message
where do you buy Redline gear oil? ive been wanting some redline MT90 for a long time!
Re: Old abused W58 Thu, 12 August 2004 01:06 Go to previous messageGo to next message
I'm not sure where you can get it as I don't live over there (I'm assuming you are from over there?)
But try
http://www.capa.com.au/prices_redline_oil.htm
Joshstix
Toymods Vice President
Re: Old abused W58 Thu, 12 August 2004 01:13 Go to previous messageGo to next message
This is the seller location page off their web site.
http://www.redlineoil.com.au/reseller-locations.as p
xl912
Re: Old abused W58 Thu, 12 August 2004 01:38 Go to previous messageGo to next message
Capacity 2.5 lts according to the book
joorsh
Re: Old abused W58 Thu, 12 August 2004 02:51 Go to previous messageGo to next message
excellent - thanks xl912!
-J-
Spanktown
Re: Old abused W58 Thu, 12 August 2004 03:01 Go to previous messageGo to next message
thanks josh and cruz
xl912
Re: Old abused W58 Thu, 12 August 2004 03:08 Go to previous messageGo to next message
IIRC it doesn't all drain when the plug is removed.
Check the level at the fill plug when topping-up. It should be just below the thread.
Try a Renault dealer for synthetic ATF $14 per litre, very good value.
Robert
bbaacchhyy
Re: Old abused W58 Thu, 12 August 2004 03:25 Go to previous messageGo to next message
CrUZsida wrote on Thu, 12 August 2004 11:06
But try
I saw the prices of the Redline stuff and Shocked Shocked Shocked
Is it really that good ?
Joshstix
Re: Old abused W58 Thu, 12 August 2004 04:17 Go to previous messageGo to next message
It completely transformed the shitty old C52 in my MR2 when I used it. It's most likely what will be going into my 3SGTE box when I find a way to remove the drain plug as well.
My old box would crunch at when changing into 2nd or third at anything over 5000RPM and in any gear when trying to shift quickly. After I put the Redline oil in it never crunched once over the next 25000 K's before I pulled it out.
bbaacchhyy
Re: Old abused W58 Thu, 12 August 2004 04:22 Go to previous messageGo to next message
Joshstix wrote on Thu, 12 August 2004 14:17
You didn't change the oil for 25,000 km ?????????
Is that recommended, or how long it took the wallet to recover Smile
Spanktown
Re: Old abused W58 Thu, 12 August 2004 05:20 Go to previous messageGo to next message
Its exspensive, but not that bad. 100 dollars instead of say 40-50 for some semi decent stuff. All the MR2 owners on www.mr2oc.com swear by the mt90 gear oil. Joshstix has just reiterated the fact that it MUST be good. My box doesnt crunch at all at any RPM, so this redline oil should make it like BUTTER! Shocked
joorsh
Re: Old abused W58 Thu, 12 August 2004 05:38 Go to previous messageGo to next message
I don't think gearbox oil really needs to be changed that often, does it?
-J-
Spanktown
Re: Old abused W58 Thu, 12 August 2004 05:39 Go to previous messageGo to next message
Maybe everyone 100,000? i certainly wouldnt change it every 25k unless it was getting noisy or there was an issue.
Joshstix
Re: Old abused W58 Fri, 13 August 2004 00:22 Go to previous messageGo to next message
bbaacchhyy wrote on Thu, 12 August 2004 14:22
How often do you change your gear box oil?
Most factory maintenance schedules say to use 100000 km maintenance intervals.
bbaacchhyy
Re: Old abused W58 Fri, 13 August 2004 00:27 Go to previous messageGo to next message
I have always changed it at about 10 - 15k. Mind you, I always gave my car hell (RA23 with 18R-G) when I had it, and now I have lease cars from wiork, so I don't care.
Personally with the Supra, as it won't be a daily driver, it will probably get changed reasonably often, but that then depends on what oil I will be using and if I have any problems.
I'll investigate this redline stuff a little more though based on the feedback
Michael B
joorsh
Re: Old abused W58 Fri, 13 August 2004 02:35 Go to previous messageGo to next message
I've had some synthetic additive stuff recommended to me. It's aparently designed for old gearboxes. You chuck it in before the new gear oil during a change, and it coats all the gears in some funky goo. Supposed to make gearchanges nicer and prolong the life of the gearbox.
What do you guys think - worth it, or a total crock?
-J-
Re: Old abused W58 Fri, 13 August 2004 03:41 Go to previous messageGo to next message
Almost all oil additives are a total crock. Just buy a good quality oil, it already contains everything you need.
river
Land of Oz
Re: Old abused W58 Fri, 13 August 2004 12:29 Go to previous messageGo to next message
I can run this shit-hot oil stuff in a P51? I got the synchro on 3rd gear starting to go. Hopefully, it may hold me over for a while.
seeyuzz
river
joorsh
Re: Old abused W58 Sat, 14 August 2004 22:36 Go to previous messageGo to next message
Well I had an additive recommended to me by someone whome I trust, so I thought I'd give it a go. It's supposed to prolong the life of old gearboxes and help smoothen gear changes.
Did the oil change with Draven yesterday and added that along with some regular 80/80 gearbox oil. Now it feels like a brand new gearbox. Couldn't be happier - no sign of crunching AT ALL.
Whether that's the gear oil change or the additive that did it, I have no idea. All I know is that, all up, it cost me less than $40.
-J-
Re: Old abused W58 Sun, 15 August 2004 06:57 Go to previous messageGo to next message
joorsh wrote on Sun, 15 August 2004 08:36
Was this someone a chemical engineer who knows the exact composition of the gearbox oil you're using?
I've said it before and I'll say it again, additives are a crock. Usually they're little more than a thickening agent, and that's what gives you better shift quality in a worn gearbox.
Spanktown
Re: Old abused W58 Sun, 15 August 2004 08:34 Go to previous message
ill be buying me some redline mt90 for my box asap, so when i put it in ill let you boys know.
Previous Topic:T18 brakes on KE30
Next Topic:why does my car jolt back and fourth?
Current Time: Sat Oct 17 06:07:40 UTC 2026
Total time taken to generate the page: 0.010890960693359 seconds
