Toymods » Tech & Conversions » URGENT HELP REQUIRED
Beej
URGENT HELP REQUIRED Wed, 11 August 2004 13:22
ok so i remove my entire intake system, replace my first rubber return hose from my blok, viola! no more leak.....now the car wont run properly
basically i start it, idles no worries, little bit of throttle, stall out, litte more throttle, fine, and RPMS' climb....any more than say 10-15% throttle, and it burbles, and the mix smells fuking rich as
codes = 24 Intake Air Temp. Sensor Open or short in intake air temp. sensor signal (THA).
31 Air-Flow Meter Signal Open cct in VC signal or short cct between VS and E2 when idle contacts are closed.
what do these mean, and how do i fix them.....my AFM riped open and i re-soldered the wires.....is it possible the board was shorted wen i soldered the connections back on ?
Previous Topic:18R-G valve gear clearances...
Next Topic:AE86 vacum hoses
Current Time: Mon Nov 2 05:25:44 UTC 2026
Total time taken to generate the page: 0.011191844940186 seconds
