Toymods » Tech & Conversions » AFM
Beej
AFM Wed, 11 August 2004 13:34 Go to next message
what AFM's from what cars will werk on my 3S-GTE???
spectral
Re: AFM Wed, 11 August 2004 14:11 Go to previous messageGo to next message
one from a 3SGTE Smile
heh sorry.
There aren't many that will work straight off. If any at all. Bascially you need to find one that has a similar voltage output to the 3S-GTE one.
Even then your standard ECU may have trouble if the voltages are even slightly different.
I don't really think the 3S-GTE AFM is the major restriction in the standard inlet tract. Its annoying piping-wise thou.
Beej
Re: AFM Wed, 11 August 2004 14:14 Go to previous messageGo to next message
thanks dude, not worried bout piping restriction....i rekon i fried mine today.....pulled out the entire AFM to get to a coolant return pipe, and pulled out the wires to the ARM thinking there was a clip.....no clip, soldered straight onto the circuit board, so i had try and re-solder, and that didnt werk, getting bad throttle issues and throwing codes
http://www.alltrac.net/phpBB2/viewtopic.php?t=201
cheerz man
HyDrA
Adelaide, SA
Re: AFM Thu, 12 August 2004 03:13 Go to previous messageGo to next message
I'm pretty sure that the AFM has a clip on wiring connector... In fact, I can't imagine it not having a clip on one!
Beej
Re: AFM Thu, 12 August 2004 05:20 Go to previous messageGo to next message
HyDrA wrote on Thu, 12 August 2004 12:43
well i hate to break it to you, but only a single wire out of the 6 wire loom has a clip (2 others do, but thats for the temp sensor). i know this becuase i had to pull mine appart and look inside!!! no clip. connectors from circuit board directly soldered to wires, no clip........im getting my circuit board repaired by a electronic engineer ATM
otherwise i think its Apexi AFC time
Beej
Re: AFM Fri, 13 August 2004 04:31 Go to previous messageGo to next message
wellt eh electrical engineer, put some wires in my circuit board for me, i soldered them onto the harness thingy, and all werks perfect so i just re-sealed the top of my AFM
$45 for the repair.....all is very very well
HyDrA
Adelaide, SA
Re: AFM Fri, 13 August 2004 04:34 Go to previous message
Good to hear!
Previous Topic:swapping a manual RA6x steering rack into an MA61...
Next Topic:1G-GE maximum power output
Current Time: Mon Oct 19 15:50:17 UTC 2026
Total time taken to generate the page: 0.0056331157684326 seconds
