Toymods » Tech & Conversions » re-map ecu or aftermarket for 4a-ge
fudge1987
Gold Coast
re-map ecu or aftermarket for 4a-ge Thu, 12 August 2004 06:30 Go to next message
I am about to turbo my 4a-ge and i was wondering if there is a cheaper aftermarket ecu or i could get a map-ecu off another toyota turbo that will suit mine or i could re-map my map sensor if you can do that, who i can i do it from, where can i get it done... all that sorta stuff... cheers
Spanktown
Inside a giant turbo (syd...
Re: re-map ecu or aftermarket for 4a-ge Thu, 12 August 2004 06:42 Go to previous messageGo to next message
im pretty sure you cant 'remap' or reburn the rom like you can with the nissan ecu's. Your best and cheapest bet is to get a 4agze ECU from either an aw11 mr2, ae92 or ae101. Thats your cheap option, or you could simple spend upwards of $800 on a piggy back (NOT reccomended) or more for a standable ecu like a microtech mtx8.
fudge1987
Gold Coast
Re: re-map ecu or aftermarket for 4a-ge Thu, 12 August 2004 08:33 Go to previous messageGo to next message
But with these maps, if i just get someone to connect them strait up will they work fine or will i have to modify them someway?
Re: re-map ecu or aftermarket for 4a-ge Thu, 12 August 2004 10:35 Go to previous messageGo to next message
you would have to run injectors that go with the ECU (e.g. 4agze ECU requires 4agze injectors, not 4age). you would also need the AFM that came with ECU (i think)
you can't modify the maps in the toyota ECU - if you want modify-able ECU, go aftermarket.
cheers, charles.
FKN16V
NSW, East Coast
Re: re-map ecu or aftermarket for 4a-ge Thu, 12 August 2004 12:11 Go to previous messageGo to next message
Save your cash and go full aftermarket.
Ask Adam at http://www.justenginemanagement.com/ he might have some second hand stuff lying around, beats paying new prices. Not that there expensive.
Steve
fudge1987
Gold Coast
Re: re-map ecu or aftermarket for 4a-ge Wed, 18 August 2004 06:15 Go to previous messageGo to next message
I got offered a 4a-gze ecu off a mr2 sw-11... will this be good... and the dude who offered it to my said that i would have to upgrade my injectors and fuel rail... do i have to, i know someone with my engine and the only thing he chaged to put a turbo with 7psi is he put an aftermarked ecu on it... will the gze ecu do the same thing?
Re: re-map ecu or aftermarket for 4a-ge Wed, 18 August 2004 06:20 Go to previous messageGo to next message
The GZE ECU will only work with GZE injectors, with NA ones, you can expect your engine to last all of a few seconds, if it'll even run Evil or Very Mad
fudge1987
Gold Coast
Re: re-map ecu or aftermarket for 4a-ge Sun, 22 August 2004 03:39 Go to previous messageGo to next message
Well.... what do you think the best way to turbo my 4a-ge bluetop would be, i have already got the turbo and intercooler and i know an engineer that will make all the manifolds and do everything for cheap, i just need the map to read boost... any1 got any ideas that will hold?
fudge1987
Gold Coast
Re: re-map ecu or aftermarket for 4a-ge Sun, 22 August 2004 05:37 Go to previous messageGo to next message
I have narrowed it down to either getting an microtech L-8 aftermarket ecu which would be suitable... BUT for a grand by itself and then the installation and tuning on top of that... would just completely blow my budget... SO i was thinking of just getting a ecu of a turbo car with the injectors, computer and afm... all i need now are details, would the gze be the only way i could go or are there other cars that would suit my set-up??? any1 got details or info, any help would be greatly appreciated
FKN16V
NSW, East Coast
Re: re-map ecu or aftermarket for 4a-ge Sun, 22 August 2004 11:22 Go to previous messageGo to next message
As stated before, you'll need afm, injectors,loom and ecu from a gze, it'll be about the cheapest and easiest option. Do a search and see what comes up heaps of info around.
Steve
Re: re-map ecu or aftermarket for 4a-ge Sun, 22 August 2004 12:30 Go to previous messageGo to next message
i have been thinking about tightarsery of this kind myself....
Pimpboy has a turbo now, and im wondering if there would be an issue using either the bigport or smallport 4A-GZE EFI systems, particularly in the igntion department?
Im not stupid so i know what i would need from a 4agze engine, im referring more to the igntion maps. would having a compression ratio of like 10.5:1 compared to 8.9:1 or 8.0:1 create issues on my engine with detonation and shite? I mean there would be a fair amount of ignition advance in the GZE ecu's wouldnt there, and wouldnt that cause problems with any decent (above 6psi) boost?
I know its not ideal, but the GZE system (ecu, loom, injectors, MAP/AFM, dizzy/CAS, and coils) is easy to come by and cheap for me.
Should i just bite it and pay for tuning?
fudge1987
Gold Coast
Re: re-map ecu or aftermarket for 4a-ge Sun, 22 August 2004 23:30 Go to previous message
well... i would bite it and get it tuned if i had the money but i dont so im going to run the gze set-up... are there and evidence of your theory? like... has any1 done this b4???can you pm me and/or add me to your msn so we can duscuss this... I am about to turbo my bluetop 4a-ge @ 7psi and need all the help i can get... any1 got any 4a-gze bits for sale... map/afm, injectors etc etc...
[Updated on: Sun, 22 August 2004 23:37]
Previous Topic:Mr2 turbo issue
Next Topic:AE101 Wiring diagrams needed
Current Time: Thu Oct 15 22:54:28 UTC 2026
Total time taken to generate the page: 0.017890930175781 seconds
