Toymods » Tech & Conversions » Toyota bearing "Mark" increments
TE72_Turbo
Toyota bearing "Mark" increments Thu, 12 August 2004 08:28 Go to next message
I need to purchase a set of main & conrod bearings for a 20V 4AG from toyota, I have the part numbers, but what exactly do the "Mark 1, Mark 2, Mark 3" designations mean? I know that for pistons they are slight diameter increments to match each bore exactly, but how much difference is there between each 'mark' with bearings?
Thanks in advance Smile
Phil
YelloRolla
On your mum!
Re: Toyota bearing "Mark" increments Thu, 12 August 2004 13:54 Go to previous messageGo to next message
Phil - I am unsure of the answer to this, but give the clearance something to the order or .002" to .0025" I guess that there would only be 1/10ths of thous in it. Why not measure the crank pins and journals and see how much difference there is? This would go a ways to telling you how close they are to each other and how bearing numbers relate.
TE72_Turbo
Re: Toyota bearing "Mark" increments Fri, 13 August 2004 11:10 Go to previous message
Thanks Jason. Found out today that the corresponding "Mark" numbers are stamped inside the block for both the main & conrod bearings from production. I was looking on the rods & crank themselves, the block has a lot of oil sludge baked onto everything, I guess the stamping will be easy to see once its had a bath Smile
Phil
Previous Topic:Help! glowing red exhaust
Next Topic:your experience with buying import motors
Current Time: Sun Nov 22 03:22:52 UTC 2026
Total time taken to generate the page: 0.0062820911407471 seconds
