Toymods » Tech & Conversions » Boost Changing
adavy84
Perth, WA
Boost Changing Thu, 12 August 2004 08:39 Go to next message
OK i have just noticed that when i floor it the boost goes up to about 13psi and then goes down to about 10psi... and in 2nd gear it goes down to 9psi. i was just wonding if this is normal as i am just using a home made boost controler (bleed valve thing).
engine is a 4agze MAP with a t25g turbo and on stock computer.
Please help
thanks.
doityourself
Hackham South Australia
Re: Boost Changing Thu, 12 August 2004 09:02 Go to previous messageGo to next message
sounds to me you need an intercooler, if not a bigger one.
anything over 8 psi in my books is too much with out a cooler of some kind, whether it is intercooled via air - air, water - air, or the old skool water injection( be warey of this one i have herd good and bad things about it), also invest in an aftermarket bleeder valve as home mades are only good if you are one of the bush mechanics ( no i am not having a dig at you), there is nothing like quality parts to make a go good, ive learnt that one.
doityourself
Re: Boost Changing Thu, 12 August 2004 09:10 Go to previous messageGo to next message
by the way i forgot to mention that u should turn the boost to 5\6 pounds before you do damage, if not already.
What u are experiencing is that air gets so warm that when it mixes with the fuel it is bieng burnt before it makes it in the combustion chamber,coz the air is hot in 1st gr and you go in to 2nd the air is raising in temp due to the lack of cooling.
When air is compressed it gets warmer. this warm charge has to be cooled for it to be effective. I am soory i dont know much about this topic too much, hope this has helped in some way.
I would love to use liquid nitrogen as a cooling method, sure the cost would make it unviable but think of the BOOST!
adavy84
Perth, WA
Re: Boost Changing Thu, 12 August 2004 12:33 Go to previous messageGo to next message
I have a VR4 intercooler and after a run all the pipes are pretty cold. but as i dont have a aftermarket computer i dont know the intake temp.
thanks for ur help.
YelloRolla
On your mum!
Re: Boost Changing Thu, 12 August 2004 13:39 Go to previous messageGo to next message
The problem is most likely caused by the boost bleed system being unable to flow enough air to control boost in the higher gears, this can be remedied by a (preferrably adjustable) restrictor between the wastegate actuator and the t piece that leads off to your boost bleed valve (not easy to tell without eyeballing it though).
edit - P.S I have not experienced the fuel burning prior to going into the combustion chamber. I ran 17+ psi with stock turbo for measured intake temps of 105 deg C.
[Updated on: Thu, 12 August 2004 13:43]
BLK1GGTE
South Eastern Subs
Re: Boost Changing Thu, 12 August 2004 14:03 Go to previous messageGo to next message
What can you use to measure your intake temerature's and where should u mount it? I know after the cooler but where?
Re: Boost Changing Thu, 12 August 2004 23:31 Go to previous messageGo to next message
doityourself wrote on Thu, 12 August 2004 19:10
Uh, dude, if that happened the engine bay would quite literally explode.
That much is fairly obvious, but if you don't know the answer why confuse the issue with incorrect information? Rolling Eyes
ke382TG
Re: Boost Changing Fri, 13 August 2004 00:55 Go to previous messageGo to next message
To throw another idea in.
In my case I could hold 18psi in first, 18 psi in second, then it would start at 18psi in third and immediately drop to 12psi then 4th gear was the same as third and 5th was the same and so on.
Problem was that the wastegate flap was being forced open by the exhaust gases and hence the boost drop. It was only noticed in the taller gears because of the increased torque loading (more exhaust gas trying to bypass the wastegate flap) and longer time spent in those gears.
Increased tension on the wastegate actuator fixed the problem perfectly!
Your prob could be this but sounds much more like it is simply a bleed valve that needs to be better setup/located.
Ensure that the wastegate actuator line is as short as possible i.e. it should ideally be from the wastegate actuator to the compressor housing (or to the first few inches of piping immediately after the compressor housing) the shorter this line is the less spiking and more stable the boost. If your wastegate line runs from the manifold the the wastegate actuator then this will almost definitely be your problem.
Locate your bleed valve close to the wastegate actuator and ensure that there is a restrictor in the line before the bleed!! Otherwise you will be bleeding off a shite load of air and not gaining much boost or getting very good boost control.
If a bleed valve can't bleed enough then you will see low boost (because more positive pressure is able to force the wastegate actuator to open the wastegate flap). It sounds like yours can bleed off enough for around 9 - 10 psi but it spikes to 13 psi due to the delayed reaction of wastegate actuator then settles down to the boost level that the bleed valve can maintain.
I am assuming the bleed valve you made has no "gate" either?
A spike of a pound or so is not much to worry about, in fact some people like a spike to give a bit of oomph at the start as it comes on boost.
I have mine setup (4AGTE) to run a low boost of 13 psi and it does not spike or drop or flutcuate at all (no gate on the low boost). High boost (19psi usually) is gated and comes on with a 1psi spike (can be set up to spike higher or not at all too) then holds the preset boost perfectly!
Hope this helps.
adavy84
Perth, WA
Re: Boost Changing Fri, 13 August 2004 03:11 Go to previous messageGo to next message
Thank you that was alot of help.
the current bleed valve does have a adjustable gate on it.. and is at about 2/3 open so i think ther isnt enought restrition in the line.
ill have a look at it now and see what i can do
ke382TG
Re: Boost Changing Fri, 13 August 2004 03:45 Go to previous messageGo to next message
From what you just described in the post above I think you mean you are going to adjust the restrictor ?? (in line before the bleed). The gate is (usually) after the bleed and will open once a predetermined pressure is reached allowing the pressure to move the wastegate actuator diaphragm.
The gate just allows boost to build a little quicker than not having a gate.
Sounds like you might be on the right track anyhow.
Let us know how you go.
adavy84
Perth, WA
Re: Boost Changing Sat, 14 August 2004 05:06 Go to previous messageGo to next message
ok i have fiddled around with the bleed valve and it has got better. But still does it.
Now another thing that i thought might effect it is the brake booster... because on idle when i pump the brakes the idel goes up to like 1500rpm which i think is due to a dammaged diaphram in the booster. I dont know but this may effect the boost changing.
does anyone know if this could be the problem. and do i need a new brake booster??
cheers again.
adavy84
Perth, WA
Re: Boost Changing Sun, 15 August 2004 10:55 Go to previous message
anyone?
Previous Topic:TA22 Suspension Setup
Next Topic:T18 brakes on KE30
Current Time: Sat Nov 21 09:02:04 UTC 2026
Total time taken to generate the page: 0.0047528743743896 seconds
