Toymods » Tech & Conversions » W58, 225 or 235 mm cover??
boxh34d
wangaratta
W58, 225 or 235 mm cover?? Thu, 12 August 2004 11:51 Go to next message
i was looking in a clutch book for my MA61 supra and found that there was 2 different sizes for the clutch cover. 225mm and 235mm. is there any way i can find out what size mine is without actually pulling it out and measuring it??
cheers people.
wilbo666
Re: W58, 225 or 235 mm cover?? Thu, 12 August 2004 12:12 Go to previous messageGo to next message
hmm clutch cover eh Razz I think you mean clutch plate?
If the car is quite stock, I believe that most (if not all 5M-E's) had the 225mm flywheel and clutch and 7M-GE's had the larger flywheel/clutch. (not sure about 5M-GE or 6M-GE's).
Chances are (just an educated guess) that you will have the smaller 225mm flywheel and cltuch if its a 5M-E MA61. Cool
boxh34d
wangaratta
Re: W58, 225 or 235 mm cover?? Thu, 12 August 2004 12:18 Go to previous messageGo to next message
lol my bad, you knew what i meant Rolling Eyes
is it just a matter of buying the larger clutch plates, or does it require other modifications to get the larger one to fit??
thanks wilbo. when it comes to the clutches in these i'll be the first to admit i dont know dick Razz
thanks wilbo.
lee.
YelloRolla
On your mum!
Re: W58, 225 or 235 mm cover?? Thu, 12 August 2004 13:32 Go to previous messageGo to next message
The flywheels are different for the 2 different clutches - the locating dowels are on a different PCD - so in short they cannot be interchanged without further modification.
wilbo666
Re: W58, 225 or 235 mm cover?? Thu, 12 August 2004 13:34 Go to previous messageGo to next message
The flywheels are actually different and you can't fit a 236mm clutch (also I believe that there is a 240mm clutch plate for the 7mge flywheel listed as well, not 100% tho) on a 225mm flywheel. Also pressure plates are different as well (makes sense).
boxh34d
wangaratta
Re: W58, 225 or 235 mm cover?? Fri, 13 August 2004 06:09 Go to previous messageGo to next message
thanks guys.
the problem is, i am in the process of ( hopefully ) acquiring a MA61 with a 6MGE engine already installed. would it be fair to presume that the 6MGE flywheels are the same as the 5MGE and 7MGE ones?? ( ie for a 236mm clutch plate ) if this is the case, is there anything wrong with buying a complete clutch kit with pressure plate and everything included for the 236mm plate?? is there anything i have overlooked, or am i completely wrong???
thanks. Confused
YelloRolla
On your mum!
Re: W58, 225 or 235 mm cover?? Fri, 13 August 2004 06:14 Go to previous messageGo to next message
I actually think that there are 2 x different clutch covers that fit the 236mm plate. I have a brand new heavy duty pressure plate here to suit a 236mm flywheel though (if you are interested). It is an exedy.
Re: W58, 225 or 235 mm cover?? Fri, 13 August 2004 06:22 Go to previous messageGo to next message
I'm pretty sure all 6M-GE's came out of cars only available with an automatic transmission, so if this 6M is in an MA61 it almost certainly has a 5M-E flywheel/clutch on it.
boxh34d
wangaratta
Re: W58, 225 or 235 mm cover?? Fri, 13 August 2004 08:24 Go to previous messageGo to next message
thanks for the replies.
it was just an out of interest question, as i dont even have this car yet, i was just looking for future reference i suppose.
cheers guys, greatly appreciated.
Looonie
Auckland, NZ
Re: W58, 225 or 235 mm cover?? Mon, 16 August 2004 23:21 Go to previous messageGo to next message
Hey guys, just wondering if you can help me out here...
I have a 1g-gte with w58 behind it, 225mm exedy 5 puck brass button clutch and 50% heavier pressure plate... and it seems to slip in 2nd now that I've got a locker and s02's on the rear...
So I'm wondering... to get a 236mm clutch in there, is it possible to just get my hands on a 7m-ge flywheel and then order an aftermarket 236mm clutch pack? Or is there something more sinister involved? :\
Re: W58, 225 or 235 mm cover?? Mon, 16 August 2004 23:34 Go to previous messageGo to next message
There's something wrong with your clutch if it's slipping behind a 1G... they're hardly torque monsters you know, and it takes a lot to make a brass-button clutch slip!
Looonie
Auckland, NZ
Re: W58, 225 or 235 mm cover?? Mon, 16 August 2004 23:47 Go to previous messageGo to next message
I know, it seems quite weird, but then 225mm clutch isn't exactly "big"... if I clutch kick in 2nd gear it seems the clutch lets go and not the rear end...
What would you suggest is wrong? I can't imagine what could be wrong personally :\
I just assumed that traction at rear end overcame clamping ability of a (IMO) small clutch...
wilbo666
Re: W58, 225 or 235 mm cover?? Tue, 17 August 2004 01:15 Go to previous messageGo to next message
Might be oil contamination? Previously, or currently....
Re: W58, 225 or 235 mm cover?? Tue, 17 August 2004 02:07 Go to previous messageGo to next message
Once they start slipping they are generally stuffed.
Looonie
Auckland, NZ
Re: W58, 225 or 235 mm cover?? Tue, 17 August 2004 05:17 Go to previous messageGo to next message
Oil contamination? Not a possibility... brand new clutch, installed it myself when I did the manual conversion...
Personally I think its just the fact that the grip at the rear end with s02's outweighs what a 50% heavier duty clutch plate can hold *shrug*
ChuckLandwehr
Re: W58, 225 or 235 mm cover?? Tue, 17 August 2004 12:00 Go to previous message
After seeing quite a few new clutches installed and slipping within a short time. It has been suggested to me that the best way to ensure a correct clutch fit, and therefore reduce/eliminate slippage, is to supply the flywheel machinist with the flywheel, clutchplate and pressure plate.
The step on the flywheel is critical, as is the thickness of both the clutch plate, and the pressure plate. If the step and/or your clutch plate are too thick, the pressure plate will have "rocked over centre" ie. the clutch is in the first stages of release! Embarassed Best bet, buy your clutch and pressure plate from the guy who machines your flywheel.
regards Chuck.
[Updated on: Tue, 17 August 2004 12:02]
Previous Topic:Pulling head off AE92 GZE without removing Engine
Next Topic:major oil leaks
Current Time: Fri Nov 20 15:02:50 UTC 2026
Total time taken to generate the page: 0.0061719417572021 seconds
