Toymods » Tech & Conversions » My new 18RG head **now with pics**
Mr DOHC
My new 18RG head **now with pics** Thu, 12 August 2004 11:57 Go to next message
finally got my new head, looks very good, very noticeable difference in the cam lobes and valve lift.
first pics will be of the old head, then the new one, u should be able to tell the difference
it has new larger cams {282 deg on both sides and 12mm lift compared to 10.3}
new oversized stainless steel Ferrea valves
slight port job
shave
http://members.iinet.net.au/~shanej/Phil/headold1.jpg
http://members.iinet.net.au/~shanej/Phil/chamberold1.jpg
http://members.iinet.net.au/~shanej/Phil/headnew1.jpg
http://members.iinet.net.au/~shanej/Phil/headnew2.jpg
[Updated on: Thu, 12 August 2004 12:27]
Mr DOHC
Re: My new 18RG head Thu, 12 August 2004 11:58 Go to previous messageGo to next message
http://members.iinet.net.au/~shanej/Phil/exhportold1.jpg
http://members.iinet.net.au/~shanej/Phil/exhportnew1.jpg
http://members.iinet.net.au/~shanej/Phil/intportnew1.jpg
http://members.iinet.net.au/~shanej/Phil/valvenew1.jpg
[Updated on: Thu, 12 August 2004 12:21]
Mr DOHC
Re: My new 18RG head Thu, 12 August 2004 12:23 Go to previous messageGo to next message
http://members.iinet.net.au/~shanej/Phil/lobeold1.jpg
http://members.iinet.net.au/~shanej/Phil/lobenew1.jpg
http://members.iinet.net.au/~shanej/Phil/valveliftold1.jpg
http://members.iinet.net.au/~shanej/Phil/valveliftnew1.jpg
Re: My new 18RG head Thu, 12 August 2004 12:24 Go to previous messageGo to next message
pics are there dude Smile
very tidy!
Did you get a weld/regrind on your stock cams or did u go for new billets?
Im dropping my 88250 head off tomorrow morning with Dominator Engine Builders, will see how that turns up! But it's designated for TURBO use, not na.
Mr DOHC
Re: My new 18RG head Thu, 12 August 2004 12:28 Go to previous messageGo to next message
just a regrind of the stock cams {88250}
Re: My new 18RG head Thu, 12 August 2004 12:49 Go to previous messageGo to next message
mmmm... so you're also going to reconsider your brake upgrade before or after you install this? Shocked Laughing
Chris Davey
sunny coast, qld
Re: My new 18RG head **now with pics** Thu, 12 August 2004 12:55 Go to previous messageGo to next message
they are some awesome pics there Phil!
it's lookin' good Smile
Mr DOHC
Re: My new 18RG head **now with pics** Thu, 12 August 2004 13:12 Go to previous messageGo to next message
already installed, just gotta setup the cams and tune it
brett_celicacoupe
townsville NQLD
Re: My new 18RG head **now with pics** Fri, 13 August 2004 06:22 Go to previous messageGo to next message
awesome, i love it. looks great Smile
how much extra power will u reckon u will get?
Re: My new 18RG head **now with pics** Fri, 13 August 2004 06:27 Go to previous messageGo to next message
SHITE!
i just dropped off my head this morning, but i cant remember which cam in intake and which is exhaust!!!
one has the part # ending in 251
the ohter has part # engine 250
WHICH IS WHICH!?!?!?
Mr DOHC
Re: My new 18RG head **now with pics** Fri, 13 August 2004 10:30 Go to previous messageGo to next message
put both in, with the slots facing UP, and the cams should be back to front to this pic, i fucked up and put the cams back in b4 i sent it away, both intake and exhaust are IDENTICAL {std 88250 cams are anyway Confused } except that they are 180 degs out of phase from each other.
if my gibberish has made any sense then u should be fine,
btw, i have got mine installed and its fine, except that when at TDC on cyl 1 the slots face straight down, so when i line up the cams i have to have is at TDC on cyl 4
Re: My new 18RG head **now with pics** Fri, 13 August 2004 11:55 Go to previous messageGo to next message
18R-G PORN!! Shocked Laughing
CelicaRA45
nth ringwood, Victoria
Re: My new 18RG head **now with pics** Fri, 13 August 2004 12:37 Go to previous messageGo to next message
so melvin you will need 4mm shims know which puts a bit of weight in to the bucket, you would of been better to weld or hard face than take the base circle away .they were designed to have 1.5mm shims up to 3.20 mm max after this the shim can move out and get stuck up under the bucket pushing the valve down further towards the piston, but only up in the high rev range 5500 onwards. be very wary about this ,seen it happen a few times as the harmonics of the engine at high rpm few bent valves and a few holes in the piston. ps my 2 cents
Machina
Ballarat, Vic.
Re: My new 18RG head **now with pics** Fri, 13 August 2004 18:28 Go to previous messageGo to next message
how are you going for clearance in the cc?
will you need relief cuts? let me know, as this seems to be interesting.
and we want to see dyno figures someday.....
well, i know i do.
M.
fade-e
Re: My new 18RG head **now with pics** Sat, 14 August 2004 02:18 Go to previous messageGo to next message
is this a NEW head or did you just get the same one acid bathed?
looks awsome though
Mr DOHC
Re: My new 18RG head **now with pics** Sat, 14 August 2004 23:19 Go to previous messageGo to next message
this is a 2nd head i bought off people100, for $100, he needed a bottom end, i needed a head so he bought a whole engine and i got the head Very Happy
celicaRA45:
i see what u mean, thanks for your concern Smile , but my dad thought of this and got longer valves, the valves are just a blank SS Ferrea valve, {originally to suit a SBC}, and he had to get the collet grooves machined and all that shit, so he got 0.100" longer. Smile
no i dont need any machining done, apparently u can run upto 302/302 duration b4 u have problems {going by the toysport.com site}
dunno about clearance but i have retarded and advanced the intake cam and it seems fine
melvin.....phil melvin
Mr DOHC
Re: My new 18RG head **now with pics** Mon, 16 August 2004 10:10 Go to previous message
nearly killed the whole engine today.
last night i was playing around with the cam timing, and when i went to bed i left the ratchet on the crank bolt, with the ratchet set to "undo". Shocked
my wife had to day off, and she had to go to the doctors, she called and said it made a weird noise on startup and then stopped, when she restarted it she heard a clunk, she looked underneath and saw my ratchet and thought i just left it on top of the engine, so she drove off to the doctors and back home...... WITH NO CRANK BOLT. Shocked
luckily the pulley didnt come off, so i put the bolt back on and its fine now Embarassed
Previous Topic:18rg in ta22
Next Topic:converting 18R turbo to EFI - update: new turbo manifold
Current Time: Fri Nov 20 20:34:21 UTC 2026
Total time taken to generate the page: 0.0053110122680664 seconds
