Toymods » Tech & Conversions » aircon/fan/cig lighter not working
DTrain
aircon/fan/cig lighter not working Thu, 12 August 2004 14:59 Go to next message
heyas, i was driving down to the coast and half way there the aircon turned off. i think it may be the relay or a fuse, but ive check all the fuses in the kick panel and they are fine - would it be one of the fuses or relays in the engine bay? if so, where do you reckon i could get one?
dave
ChuckLandwehr
Re: aircon/fan/cig lighter not working Fri, 13 August 2004 05:57 Go to previous messageGo to next message
Dave, check your fusible links in the engine bay at the battery terminal. You should be able to pick up a fusible link at any Auto electricians, wreckers or parts dealer. If the link is blown, you will have to unbolt it, they do not pull out! Also if it has blown, check for a reason for it blowing. If the A/C fan or Clutch is stuffed, you were probably drawing too much current, and that's why the link blew. Hope this helps a little.
regards Chuck.
DTrain
Re: aircon/fan/cig lighter not working Sat, 14 August 2004 06:32 Go to previous messageGo to next message
hmm are you talking about the three fuses (an 80amp and the other two i cant remember) at the positive? if so, they seem to be fine - the links are all good. how do i check whether the aircon fan or clutch are stuffed - where are they located? im fairly newb at cars
dave
sideshow
Re: aircon/fan/cig lighter not working Sat, 14 August 2004 07:09 Go to previous messageGo to next message
just check all fuses right hand kick panel
bound to be one of them
fuseable links would stop car from runnin if they were blown
Re: aircon/fan/cig lighter not working Sat, 14 August 2004 07:16 Go to previous message
i thought aircon was on the Ign circuit, not accessory circuit? or is that just the compressor clutch?
i was going to suggest that your accessory circuit fuse has probably blown.
how to check if aircon clutch is stuffed? disconnect wire going to aircon compressor - while carefully watching the pulley on the front of it, touch that wire to + on the battery - pulley should click in as you touch the battery, and out when removed.
Previous Topic:MAP GZE oxygen sensor question
Next Topic:7mgte diagnostics
Current Time: Sat Oct 24 00:20:42 UTC 2026
Total time taken to generate the page: 0.0048530101776123 seconds
