Toymods » Tech & Conversions » Why am I crunching 2nd to 3rd gear ??
ed_ma61
Lost in the K hole
icon4.gif  Why am I crunching 2nd to 3rd gear ?? Fri, 13 August 2004 04:21 Go to next message
I seem to have a problem with my w58 'crunching' heavy 2nd to 3rd upshifts, almost exclusively when at high rpm exiting a decent corner, when upshiting into the straight.
its like the 3rd syncro isnt working, and the teeth go BBBRRRRRRRRR against each other before catching and clunking into gear. like a missed shift, but i KNOW the clutch is properly disengaged.
now before anyone has a crack about some stupid granny shifting, or my ill co-ordinated unko style, i can happily say ITS NOT ME! i originally thought i mustve been a little too eager on the stick and was hitting the shift early, but ive been VERY creful to make sure the clutch is fully disengaged before trying to punch 3rd, and its STILL happens.
the interesting thing is solid shifts in a straight line are fine. i never have issues with the box other than when heavy cornering and really pushing the rpm in 2nd before the shift.
is it perhaps the box fluid sloshing around during a corner? what can i do to help avoid this?
suggestions to different box fluid? fluid levels? over fill it a bit? additives? add a bit of auto trans fluid (heared that once somewhere).
its a mkiv supra w58 in top nick, i dont think it should be doing this. any suggestions would be appreciated.
ed
bbaacchhyy
Re: Why am I crunching 2nd to 3rd gear ?? Fri, 13 August 2004 04:29 Go to previous messageGo to next message
I'd assume that all of the shifter bushings are OK, so then it probably will fall down into the area of shift fork or damaged/worn synchro.
Did this suddenly start happening, or slowly get worse ?
At high revs, if you shift slow, and all other situations, is the shift OK ?
To see if it is the synchro, drain the oil and see if there are brass style silt in there Sad
Michael B
Re: Why am I crunching 2nd to 3rd gear ?? Fri, 13 August 2004 04:37 Go to previous messageGo to next message
The fact that it happens at high rpm only points to worn synchros. Pretty common on older W58's. Solution: rebuild box, or even better, get a late-model W58 with double-row synchros on 2nd and 3rd. Quick-shifting goodness!
Re: Why am I crunching 2nd to 3rd gear ?? Fri, 13 August 2004 04:42 Go to previous messageGo to next message
This is the noisy box Ed? The one that came out of the JZA80 that flipped eleventy billion times one night?
Synchros is what it sounds like.
ed_ma61
Lost in the K hole
Re: Why am I crunching 2nd to 3rd gear ?? Fri, 13 August 2004 05:07 Go to previous messageGo to next message
Norbie wrote on Fri, 13 August 2004 14:37
its IS a late model box. reasonably low km's too.
and also, yeah, hapens at high RPM but ONLY when cornering... NEVER when shifting hard along a straight.
and dave: yeah, its the box that flipped eleventy billion times, but its not noisy. that was me having the tailshaft centre bearing installed upside down Rolling Eyes
Re: Why am I crunching 2nd to 3rd gear ?? Fri, 13 August 2004 06:20 Go to previous messageGo to next message
LMAO!
Re: Why am I crunching 2nd to 3rd gear ?? Fri, 13 August 2004 06:35 Go to previous messageGo to next message
cos u iz da massifzt dong!
monkeymajik
Re: Why am I crunching 2nd to 3rd gear ?? Fri, 13 August 2004 06:55 Go to previous messageGo to next message
is the gbox oil level low? and it is sloshing to one side, thats why it only happens when cornering?
Just an idea.
xl912
Re: Why am I crunching 2nd to 3rd gear ?? Fri, 13 August 2004 09:54 Go to previous messageGo to next message
See thread titled 'Old abused W58' for lubricant suggestions to soothe those syncros.
Otherwise check clutch disengagement, oil level.
Robert
YelloRolla
On your mum!
Re: Why am I crunching 2nd to 3rd gear ?? Fri, 13 August 2004 10:03 Go to previous messageGo to next message
Ed, when cornering at massif G forses you is prolly forgetting to be depressing the pedal on the far left.
I am liking low oil or too high, or viscosity too high or that you simply cannot drive.
Maybe the innards are still upside down? they may have flipped eleventy billion and one half times.
Solution = boost + auto
ed_ma61
Lost in the K hole
Re: Why am I crunching 2nd to 3rd gear ?? Fri, 13 August 2004 10:20 Go to previous messageGo to next message
yeah, maybe i need to get me one of them G-Suits that them fighter pilot hero guys wear... give me massif powah in my legs for punching dem well-'ardcore gears without losing consciousness Rolling Eyes
ill have a look and see what oil i can get over the weekend, do a change and see what happens. a little birdy has suggested MTX80 race motorbike box oil with ye-olde nulon teflon additive...
anyone have thoughts on royal purple oils?
ed
Re: Why am I crunching 2nd to 3rd gear ?? Sat, 14 August 2004 06:02 Go to previous messageGo to next message
ask Rod about Royal Purple.
Classique71
Colac, Victoria
Re: Why am I crunching 2nd to 3rd gear ?? Sat, 14 August 2004 08:19 Go to previous messageGo to next message
munch mucnh syncros for lunch
rebuild! upgrade! bigger faster stronger !
ed_ma61
Lost in the K hole
Re: Why am I crunching 2nd to 3rd gear ?? Sat, 14 August 2004 11:38 Go to previous messageGo to next message
if it is a fubar synchro - how the hell did i kill it so quickly???
Classique71
Colac, Victoria
Re: Why am I crunching 2nd to 3rd gear ?? Sat, 14 August 2004 11:51 Go to previous messageGo to next message
its a second hand box right ?
was it rebuilt or chuckled in ?
the prevous flipcar owner coulda got it to just about dead phase before you bought it
ed_ma61
Lost in the K hole
Re: Why am I crunching 2nd to 3rd gear ?? Sat, 14 August 2004 11:56 Go to previous message
nah i know the history of the box quite well. id say its got maybe 60k on it now, around 40k when i bought it. the donor was a converted auto to man JZA80 (2jzge) and the box was purchased new from toyota at the time of the conversion (in japan).
i drove the box in the jza80 in syd on several occasions - never had a drama, and i dont think it was injured on the evening of "dude, I flipped da car". Ive never really had a drama in my supra either - ive just noticed this occuring (not just recently either), and i figure its now about time to see wtf is going on.
[Updated on: Sat, 14 August 2004 11:59]
Previous Topic:4k turbo???
Next Topic:Oil Leaks (AE92 w/ AE101gear)
Current Time: Wed Oct 21 08:58:58 UTC 2026
Total time taken to generate the page: 0.14719796180725 seconds
