Toymods » Tech & Conversions » RA28 Dash
thomasbl
Melb
RA28 Dash Fri, 13 August 2004 10:37 Go to next message
What other dash tops will fit into a RA28? Will 23 dshes fit in? What about earlier models? Have a cracked top section and i figure it will be cheaper to find a replacement than get it repaired?
EDIT- I dont wont to hear any shit about trying to fit 23 dashes in my car either! hehe. Should choose my words a little better...
[Updated on: Fri, 13 August 2004 10:40]
rxtoy
Auckland NZ
Re: RA28 Dash Fri, 13 August 2004 11:42 Go to previous messageGo to next message
TA23, RA23 and RA28 dashes are all the same, problem is that most of them are in the same boat as yours, with at least cracks and some a lot worse, mines cracked right through and split into two pieces Sad
i've seen recovered ones and they look pretty mint but fairly expensive unless you know the right people, think its about $700 ish to get done over here (NZ), probably similar in Aussie.
i was having a look through a TT132 corona not that long ago and the dash top looked very similar, as in width and basic layout. i think you'd have to change the instruments as well and they were square and slightly moderner looking but i didn't like them too much, don't think they'd suit the celicas but might be worth looking into for you? there's a few other compatible bits like almost everything in the engine bay including crossmember's.
TA22 dashes are different, the instruments and dashtop are all completely different and i think you'd have to swap the frame behind the dash to get it to fit. most of them have the same cracking problems as the 23/28's anyway.
Matt
ChuckLandwehr
Re: RA28 Dash Sat, 14 August 2004 04:38 Go to previous messageGo to next message
Buy a copy of "The Parts Peddler" about $3.00 from your local newsagency. A mob called Restore a Dash has been doing my 22 and 23 dash pads for years, cost about $120.00. They use a vacuum forming process, and come in any colour you want!
regards Chuck.
thomasbl
Melb
Re: RA28 Dash Sun, 15 August 2004 06:51 Go to previous messageGo to next message
Thanks Chuck.
That might be a good option considering it is going to be tough to get my hands on a sec hand replacement black dash.
Cheers.
Tom
rxtoy
Auckland NZ
Re: RA28 Dash Sun, 15 August 2004 11:23 Go to previous message
i'd be very interested in a phone number and address for that place if anybody could help me out? would work out cheaper to send mine over there and get it sent back for a price like that,
Matt
Previous Topic:ct26 inlet + outlet size - help
Next Topic:TA22 Suspension Setup
Current Time: Sat Nov 21 08:47:37 UTC 2026
Total time taken to generate the page: 0.0045318603515625 seconds
