Toymods » Tech & Conversions » why does my car jolt back and fourth?
ae82boy
why does my car jolt back and fourth? Fri, 13 August 2004 13:00 Go to next message
hi fello toymoders, iv got a problem wid my FWD ae82, basicly
wheneva im at a low speed,(in 1st) then start accelerating, for the first 15metres or so my car jolts back and fourth, also this happeneds when i dont give enough trottle after a gear change, i have checked all my my engine mounting brakets, none are brocken. any ideas.
ps. 1st post on toymods =P
any input would help.
sik sx
Sunshine Coast
Re: why does my car jolt back and fourth? Fri, 13 August 2004 13:06 Go to previous messageGo to next message
timing.make sure that is perfect then see if that helps.good luck
Dodgy_Haro
Re: why does my car jolt back and fourth? Fri, 13 August 2004 14:37 Go to previous messageGo to next message
Or are you low on fuel?
From personal experience, fuel starvation makes the car 'bunnyhop' at times, especially if you're just about to run out ...
Btw, welcome to the club! Smile
Hunty
Re: why does my car jolt back and fourth? Fri, 13 August 2004 15:24 Go to previous messageGo to next message
how ya lettin the clutch out???
DTrain
Re: why does my car jolt back and fourth? Fri, 13 August 2004 15:31 Go to previous messageGo to next message
mine does the same, i think it is timing related
Satoshi
Re: why does my car jolt back and fourth? Fri, 13 August 2004 17:23 Go to previous messageGo to next message
i got the same problem as u..its pretty annoying at times especially when u are looking for a carpark u just wanna go slow..and there's people around u..and your car just rock front and forth looking like an idiot..
i've not check my timing yet..but a friend of mine told me to check my TPS or TRP..cant remember what its called...there's a certain reading that u must reach or something...i've yet to check it ...
i've not check my timing as well...
can someone explain if this gotta do with the tps or trp (whatever its called)??
ae82boy
Re: why does my car jolt back and fourth? Sat, 14 August 2004 03:29 Go to previous messageGo to next message
thanks for all your replys. Hunty: i usally drop the clutch fairly quickly, but i compernsate wid bit more trottle.
Dodgy_Haro
Re: why does my car jolt back and fourth? Sat, 14 August 2004 06:44 Go to previous messageGo to next message
Satoshi wrote on Sat, 14 August 2004 03:23
That's just the nature of a 4AG being a high engine rev'er ... it's just lumpy at low revs.
Super Jamie
On Probation
North East NSW
Re: why does my car jolt back and fourth? Sat, 14 August 2004 09:06 Go to previous messageGo to next message
this is called "bunnyhopping". it's what p-platers do. learn to drive better and your car will give a smoother ride
ae82boy
Re: why does my car jolt back and fourth? Sat, 14 August 2004 09:21 Go to previous messageGo to next message
thanks Dodgy_Haro for the info and Super Jamie, your spot on, i am a P Plater, ill guess ill bear wid, an accel slowly.
brett_celicacoupe
townsville NQLD
Re: why does my car jolt back and fourth? Sat, 14 August 2004 09:58 Go to previous messageGo to next message
my friend had a ae82 and it is a naturally jolty car. little while ago the timing got out a little and it was even worse. try checkin the timing if you havent already.
brett
Chaos
Re: why does my car jolt back and fourth? Sat, 14 August 2004 10:21 Go to previous messageGo to next message
I've got a twin cam and that happens to me too... just ease the throttle on at slow speeds and all is well.
jackel
Re: why does my car jolt back and fourth? Sat, 14 August 2004 10:55 Go to previous messageGo to next message
Super Jamie wrote on Sat, 14 August 2004 17:06
bahahaha
Super Jamie
On Probation
North East NSW
Re: why does my car jolt back and fourth? Sat, 14 August 2004 13:17 Go to previous messageGo to next message
don't worry, we all had to get rid of our driving partner "captain kangaroo" at one point Smile
the clutch is there to be slipped, slip it. don't ride it for extended periods of time or at high rpm, but its purpose is to be let out slowly and provide a smooth transition between two parts travelling one speed (flywheel) and another speed (drivetrain), think of it as a synchro that you actuate with your leg
the clutch can be let out fast at first, when it's all the way down, but slow your foot as you come closer to the take up point. almost to the point where you let it off delicately and softly. every car will have a different clutch take up point. letting the clutch out fast (dropping, popping or sidestepping) will load up the drivetrain, and if you're at low enough rpm you'll bunnyhop. if you're at high enough rpm you may grab traction and go forward quickly (a "launch"), or you may exceed the grip limit of your tyres (do a "big fat smokey") if your car is powerful enough
carsanactra
melbourne
Re: why does my car jolt back and fourth? Sat, 14 August 2004 15:30 Go to previous messageGo to next message
yep same here. also when ur cruising along and take ur foot all the way off the accelerator, the car will jolt backwards a little, and when u put ur foot back on, it lurges forward.
the same thing happens when im going arounda parking lot too. the way i get around it, when ur going slow around a car park, just roll, or and when u need to move again, wait till teh point that ur almost stopped, and then take off as if u were takeing off from the lights (slip cluth etc) or put it into second and let teh clutch out slow.
DONT try to go around teh car park in first the whole time, it WILL NOT work!
ae82boy
Re: why does my car jolt back and fourth? Sun, 15 August 2004 05:31 Go to previous messageGo to next message
ummm, going over a speed humps is the worst, especially in busy shopping malls, where thes like 1 every 15m or so, but its not all bad. i luv my 4age:D
Chaos
Re: why does my car jolt back and fourth? Sun, 15 August 2004 07:55 Go to previous message
they just werent made for going slow Evil or Very Mad
Previous Topic:Old abused W58
Next Topic:18RC Nitrous Setup
Current Time: Wed Oct 14 12:07:20 UTC 2026
Total time taken to generate the page: 0.28244996070862 seconds
