Toymods » Tech & Conversions » Spark Plug & Timing Q's
GZETrueno
Spark Plug & Timing Q's Fri, 13 August 2004 19:34 Go to next message
I know that the spark plug gap for blue top engines is .044, is it different for the red top/late model 4agze? Something like .032?
The 4agze has a timing pin to read by sticking out of the timing cover, so do you just ignore the timing numbers on the block? I also have 3 tick marks on the crank pully, I'm pretty sure that the far left one is TDC so is the far right one 10 degrees?
feral4mr2
Bundaberg, Qld.
Re: Spark Plug & Timing Q's Fri, 13 August 2004 23:31 Go to previous messageGo to next message
i ran my gze with .8mm plug gap.
you dont need the numbers that are on the plastic cover, use the timing pointer and the 3 notches on the crank pully to adjust your timing. yes the far left is TDC and the middle notch on the pulley is 10 degrees base when the diagnostic pins are jumpered.
http://www.members.aol.com/feral4mr2/images/timing 4age_ze.jpg
drift86levin
brisvegas
Re: Spark Plug & Timing Q's Sat, 14 August 2004 00:47 Go to previous messageGo to next message
whats the far right one? so the timeing marks go TDC - 10 - ?? deg
[Updated on: Sat, 14 August 2004 00:49]
feral4mr2
Bundaberg, Qld.
Re: Spark Plug & Timing Q's Sat, 14 August 2004 02:52 Go to previous message
click the link i posted and it should be prity obvious (eg. look at the top right hand picture and read the text with 9.9 at the start of it). Wink
Previous Topic:lt2000 Manual Conversion
Next Topic:Interim conversion - 1JZ palletmobile!
Current Time: Sat Oct 24 22:22:09 UTC 2026
Total time taken to generate the page: 0.0043520927429199 seconds
