Toymods » Tech & Conversions » MAP GZE oxygen sensor question
Rolla Pat
Montreal, Canada
MAP GZE oxygen sensor question Fri, 13 August 2004 20:12 Go to next message
Hi guys,
We're wriring up the gze right now (it's a map GZE) and we're up to doing the oxygen sensor.
Here's our questions:
1. How many wires does the O2 sensor for the map GZE have?
2. If I look at this diagram, seems the O2 has only 2 wires, a number "2" going to HT and a number "4" going to OX. I know personally that a 2 wire heated oxygen sensor doesn't exist so what happened to wire "1" and "3" ? Is this an error?
http://www.club4ag.com/faq%20and%20tech_pages/Tech %20Photos/AE92_4AGZE_ECU_2.jpg
For me it doesn't make sense that the O2 pin and HT pin are wired together with a resistance btween them... makes no sense?
If it is an error, what is the correct wiring path for the 4 wire o2 sensor for a map GZE?
Your help with this would be greatly appreciated Wink
Thanks!
Patrick
Re: MAP GZE oxygen sensor question Sat, 14 August 2004 01:52 Go to previous messageGo to next message
that 'resistance' "X" is the O2 Senosaa...
of a 4 wire, 1 goes to signal, 1 goes to power for heater.. and the other two wires are ground (seperate ones).
as for the GZE diagram, i can't help you.
those dashed lines (vaguely off the O2 wires) are shielding (Shiirudo) to reduce interference to the O2 signal.
sideshow
Re: MAP GZE oxygen sensor question Sat, 14 August 2004 07:21 Go to previous message
that diagram isnt quite clear
the ecu has an
ox pin
this is ox signal to the ecu
there is also a ht pin i think which is the earth for the heater
the power side of the heater comes from black with red wire i think
why r u wiring ox sensor
did u not get full loom with it
dont mix the 0x wires up cause u fuk it real fast
Previous Topic:1GGZE into 1984 4x4 Hilux
Next Topic:aircon/fan/cig lighter not working
Current Time: Sat Oct 24 01:24:38 UTC 2026
Total time taken to generate the page: 0.0052051544189453 seconds
